It is currently Fri Aug 21, 2026 4:32 am
PostPosted: Wed Apr 06, 2011 5:30 am
The roller furling collar appears to be slipping upward on the TI's mast.
These issues were first reported on the Hobie forum in early 2009.
http://www.hobiecat.com/forums/viewtopic.php?f=75&t=20914&hilit=mast+furl+glue&start=0
http://www.hobiecat.com/forums/viewtopic.php?f=75&t=13068&p=73301&hilit=mast+collar
Is the TI susceptible to this problem too?
Marc K
2010 Hobie Tandem Island
Boynton Beach, FL
PostPosted: Wed Apr 06, 2011 10:58 am
One of my AI's masts just starting slipping upward too.
PostPosted: Wed Apr 06, 2011 11:20 am
If the picture shows a TI mast with a slipped drum... I guess it is.
Correction is to re-bond with Epoxy. I'm sure that has been discussed here, so a simply forum search should locate needed info. This would be covered by warranty of course, so a dealer can do it if needed.
PostPosted: Thu Apr 07, 2011 9:30 pm
My 2011 TI also had slipped up. In the process of re-epoxy . First clue was the clamp on the boat was not engaging the furling drum without some help. I thought I had lost adjustment in the V bolts but the mast collar had slipped up a 1/4" .
