It is currently Sun Jun 14, 2026 5:54 am
Post new topic Reply to topic  [ 234 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 16  Next
PostPosted: Wed May 18, 2011 7:36 pm
Matt
Is the replacement program open to 09 AI's too?
PostPosted: Wed May 18, 2011 7:45 pm
Bob L. wrote:
Matt
Wishful thinking! :(
That's why many are selling their older AI's and buying 2011's. (can't retrofit the new rudder)
PostPosted: Wed May 18, 2011 8:06 pm
Got mine today! Watched the video. It looks pretty straight forward. I like Taby's idea on crossing the lines to give sailing tiller performance but could be confusing with the other 3 teammates (we have 2 TI's) who are new to sailing. I think we will stick with the standard.
Can't wait to install it.
Thanks Hobie!
Wile-E-Kayak
San Jose, California
TI - AUG- 2010
PostPosted: Thu May 19, 2011 1:47 pm
Thanks Hobie. As I went out to lunch there was a package on the porch, wow "it's a new rudder". Now can't wait to install it. Must watch video. Lets see...crossing lines? Ok, got to think about this does this mean push tiller to port turn to port?
Sailing Fishing Exercise equals the Good Life.
2011 Hobie Tandem Island
PostPosted: Thu May 19, 2011 2:36 pm
Ok, new rudder is necessary, but what about my expensive Hobie TI boat cover that's less than 4 months old. With the new rudder I can't leave rudder in down position (for obvious reasons)...can't leave rudder in up position and still use the boat cover for travel. Matt do you have any suggestions because I do like to travel with the cover on to protect my TI investment and to keep fingers of of my stuff when getting gas or stopping for lunch?
PostPosted: Thu May 19, 2011 4:04 pm
Pull the rudder pin and bungee the rudder assembly to the aft deck.
PostPosted: Thu May 19, 2011 4:48 pm
Thanks Matt. I was looking at the set up and saw that was going to be the best and easiest solution, I feel more comfortable knowing that's your opinion too.
Ken
PostPosted: Sun May 22, 2011 1:17 pm
Hi Matt.
I never registered my boat and I'm a bit unclear on what that implies? Will it only result in the rudder being sent to my dealer insted of being sent directly to me or will I also have to wait longer for it? I live in Sweden by the way if that makes a difference.
PostPosted: Sun May 22, 2011 8:28 pm
reconlon wrote:
Bob L. wrote:
Matt
Why wishful thinking? the rudder was/is an issue with the 2009 AI's also, why should they be left out?
some will still be under warranty and others only just out, and the rudder was identified by Hobie as an issue before any were out of warranty!
Hobie Adventure Island (Yellow Papaya)
Hobie Tandem Island (Yellow Papaya)
PostPosted: Sun May 22, 2011 8:50 pm
Sorry I wasn't clear. The transom on the 2011 AI's (where the rudder mounts) is completely different from the 2010 and earlier AI's. It almost impossible to change the older transoms or the newer rudders to be compatible with each other.
I have 4 older AI's and would love the new rudder too! :(
PostPosted: Mon May 23, 2011 5:57 am
I recieved my new rudder this weekend and installed it so that the rear hatch is not blocked. Matt what is the reason Hobie has the old steering lines cut instead of just attaching them to the new rudder? The overall system is still only as strong as the thinner line currently in the hull.
I went out on a trial run with the new rudder and when a large gust hit the boat, I was able to bear off and increase speed where the old rudder would have loaded up and lost control. The ability to use the rudder in shallow water is an appreciated bonus as well.
Thanks for the much needed upgrade.
:D
Louis
Marietta Ga.
PostPosted: Mon May 23, 2011 8:45 am
The threading of the lines to the rudder was considered more difficult for users in the field. The lines inside are PLENTY strong. The Spectra has HUNDREDS of pounds breaking strength. We upgraded the new system out of an over abundance of caution.
PostPosted: Mon May 23, 2011 2:47 pm
Louis,
Can you tell us how you installed the new rudder using the original existing spectra lines?
Sun E Sailor
Ezra Appel
Palm City, Florida
2014 Tandem Island
PostPosted: Mon May 23, 2011 3:52 pm
Just received my TI replacement rudder today on Maui. Thanks Hobie guys! 8)
PostPosted: Mon May 23, 2011 4:01 pm
Anyone in Australia received theirs yet?
H@mmer
"Intelligence is nothing without imagination"
