It is currently Thu Aug 20, 2026 7:58 pm
PostPosted: Mon May 23, 2011 9:38 am
I experienced a problem with the tiller connection last time out. Inserting the tiller cross bar to the rudder/tiller arm was tighter than usual. When the day was over, removing the tiller cross bar was very difficult. It was if the connection swelled. Has anyone else experienced this and anyway to avoid it?
PostPosted: Mon May 23, 2011 6:21 pm
The only way I found to make it easy to insert or remove them, was to leave them in an unheated garage through an Indiana winter. :wink:
You can try spraying them with Sailkote or another dry lubricant, but if you disassemble them on a regular basis, I would strongly recommend upgrading the elbows with Hobie part number 1957. Otherwise, everytime they heat up, the rubber pieces will swell and get tight.
And if you still have the original black tendons, it's only a matter of time till they will fail anyway. At least get the white re-inforced tendons before you wrestle too much with the snug fit.
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
