It is currently Sun Jun 21, 2026 12:47 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: Righting line
PostPosted: Wed Jun 01, 2011 5:25 pm
Is your mast waterproof? I have been over many times and never gone turtle. When I first bought my used boat, I dismantled the mast and resealed the foam in the ends and also sealed every rivet and screw. It just takes a bit of silicone and some time. If your mast filled with water, that is a tremendous weight to try and lift up. To get it to the surface would be no big deal as the water is neutral while submerged, but 8 pounds a gallon as soon as it breaks the surface. Quite a load.
Also, did you swim the bows around into the wind?
Definitely get a harness. Trapping out is how this boat sails best, and it will help your arms not get so tired trying to right the boat. Keep at it.
PostPosted: Wed Jun 01, 2011 5:32 pm
191 lbs is far too little weight to right a Hobie 16 unless the wind is howling.
You need a bucket or a righting pole.
PostPosted: Wed Jun 01, 2011 6:39 pm
Mast is sealed
The mast was pointed into the wind. With hindsight, I should have.
Indeed, my arms were so tired from all the pulling that initially I couldn't climb back on board.
Still, which bob?
PostPosted: Thu Jun 02, 2011 5:42 pm
euroslacker wrote:
Still, which bob?
Baby Bob
PostPosted: Fri Jun 03, 2011 7:58 am
I just use some cheap braided poly rope tied to dolphin striker. Tie it out of way then throw over haul when ya flip. The stretchy bungee hobie system I was using before was sooooo heavy when wet and it was always soaked weighing like 6+lbs so I got rid of it.
PostPosted: Fri Jun 03, 2011 1:10 pm
otterpop wrote:
Baby Bob
okay, I am getting
1. Baby bob
2. Righting bucket
3. Hobie captain's harness
