It is currently Sun Jun 21, 2026 12:58 pm
 Post subject: Tramp Replacement?
PostPosted: Fri Jun 24, 2011 1:38 pm
I picked up a mesh one on ebay. How long should replacement take? What are the advantages and disadvantages of the mesh VS. solid tramp? Any recommendation as to how to make the replacemetn efficitent?
Thanks!
Lee
 Post subject: Re: Tramp Replacement?
PostPosted: Sun Jun 26, 2011 3:18 am
I also have the enviable task :wink: of replacing my lacing before our summer comes around here in Australia. It's primarily so I can replace the eyelets in the tramp, but I don't think it's ever been done since it was new so it'll be a good opportunity to give it a good going over and freshen-up.
My dealer has told me it's a job that CAN be knocked over in a day.
We'll have to wait and see...
'97 Hobie 16.
Skype: rob_arnolda
PostPosted: Sun Jun 26, 2011 5:06 am
The FAQ has the lacing instructions.
Marc...
PostPosted: Mon Jun 27, 2011 4:07 am
I just swapped tramps on a boat I sold, it took just under 3hrs to install and lace a snug fit by myself. I like the mesh tramp, I think it lets air pass though when flying a hull rather than becoming another sail (from the bottom) to help push you over. Only down side, in my opinion, is it can be hard on the knees
Buxton
18' T16 Silent Lightning (16' T2 Hybrid)
11' H16 White Lightning
79' H16 Green Lightning
PostPosted: Mon Jun 27, 2011 8:30 am
I bought a mesh tramp from ebay last year and installed it on my boat early last season. When I first installed the tramp I only used hand and arm strength to get it tight. It was fairly tight but seemed to get some stretch after a few times out. I tightened it up agian shortly after this time using a ratchet strap around the tramp frame to deflect the sides in a little. When I pulled the tramp lacings tight, tied them off and removed the ratchet strap the tramp was extremely tight. This also helped to stiffen up my boat significantly. Everything seemed to strecth just a little more and went through the process one more time and have not noticed any more stretch.
If you use a ratchet strap be careful not to bend the side bars. I imagine it would also be possible to pull the grommets out of the tramp when you release the rachet strap. I guess this is an easy does it process.
PostPosted: Thu Jun 30, 2011 12:55 pm
Thanks for the replies; I haven't started yet but should perhaps even next week. Still haven't done the hull leak test either although I purchased an electri air puum at Harbor Freight for the job. I didn't even think of replacing the grommets but the Tramp has no hiking straps currently and I'd like to have them available.
PostPosted: Fri Jul 01, 2011 7:23 am
Love the official hobie mesh tramp that I bought for my h16... worth the money! As for how long to install, it didn't take me very long at all. You have to spend some time tightening things up.
1982 H16 (C:\Worthy)
Yellow/White Prism type sails
