It is currently Sun Jun 21, 2026 5:38 pm
 Post subject: Quick Pins?
PostPosted: Tue Jul 05, 2011 4:55 am
Taking a poll:
Can I use quick pins on the Forestay to chainplate & Main Block to traveller?
If so, what pin(s) from Murrays are recommended?
'81 H16 yellow hulls
 Post subject: Re: Quick Pins?
PostPosted: Tue Jul 05, 2011 5:30 am
I use one on the block/traveler. I keep it leashed to the block so I don't lose it. Not sure which one at Murrays but I think its 3/16"
PostPosted: Tue Jul 12, 2011 12:51 pm
Crieke,
Quick pins are the way to go!!! I use several; it makes setting up and tearing down my boat so much faster, which means more time to SAIL.
Here's what I use:
1/4 x .5 for attaching the jib tack to the 10-hole adjuster (chain plate?)
1/4 x .75 for pinning the forestay to chain plate when stepping the mast
1/4 x 1.00 for attaching the hiking stick to the tiller crossbar
3/16 x .75 for attaching main block to travel car
I have each one leashed also so they don't go in the drink if they happen to slip out of my hands.
I also use a small SS carabiner (vs a shackle) on my jib halyard for easy on/off when raising/lowering my jib.
The SS quick pins aren't too cheap, but they are definitely worth it.
Ciao
KU
'79 H16
#64048
#58757
