It is currently Sun Aug 02, 2026 1:55 am
 Post subject: Mast w/comp tip
PostPosted: Tue Oct 21, 2003 8:30 pm
How much should a h16 mast w/ comp tip weigh? I just helped a H16 sailor take down his all aluminum mast and it seemed a whloe lot lighter.
Is ther a difference?
Harry
PostPosted: Wed Oct 22, 2003 10:20 am
There should be very little difference in weight, but all masts vary due to differences in wall thickness of the aluminum etc. There is a several pound swing over the years and even between batches of aluminum from extruders. Could be the CompTip had water?
 Post subject: Water
PostPosted: Thu Oct 23, 2003 9:45 pm
:?: How do you check for water?
Last year I put her over and got the mast off the bottom, but I resealed the mast. The rest of the mast sounds empty when stepping the mast. I've a few pushed through rivets that makes the mast sound like a "rain stick" found in one of those nature stores.
thanks
Harry
 Post subject: Check for water?
PostPosted: Fri Oct 24, 2003 2:42 pm
Slosh test of course!
