It is currently Tue Jun 16, 2026 1:17 am
 Post subject: hull paint/repair
PostPosted: Fri Jul 01, 2011 7:33 pm
I just bought a Hobie 16 which needs the hulls refinished. I know there are a million or so threads about painting hulls but I have a problem, right on the bottom of the hulls the paint had been completely destroyed from dragging the cat on the beach revealing the weave of fiberglass. How should I go about repairing/painting this? what type of paint should I use on the hulls? I want to do this will as little strain on my wallet as possible. Thanks
'73 Hobie 16
1970's styrofoam snark
 Post subject: Re: hull paint/repair
PostPosted: Mon Jul 11, 2011 4:23 pm
viewtopic.php?f=20&t=5713
PostPosted: Tue Jul 12, 2011 5:50 am
I recently spend 16 hours removing/sanding off paint from my hulls in order to be able to do a bottom job on mine. Don't use paint, you'll just suffer later when it's time to do your next bottom job.
Paint will wear out on the beach much quicker than gelcoat. At the marine store I bought my supplies, a quart of marine paint was a few bucks more than gelcoat, so it was a no brainer. I don't know if the salesman knows his stuff or not, but he was telling me that top coat paint is not to be used below the water line because it's not waterproof (just very water resistant) and that it would eventually blister, expose the fiberglass, which means I'd have to repair it again sooner rather than later.
Marc...
