It is currently Sat Aug 08, 2026 9:30 pm
 Post subject: hobie 17 rudder blades
PostPosted: Wed Aug 03, 2011 7:23 am
Can I mount on my Hobie 17 the rudder blades of Hobie 18 or a Tiger?
PostPosted: Wed Aug 03, 2011 8:24 am
The Hobie Wave, 14, 16, 17, & 18 all use the same rudder blades.
The blades off of an 18 will be a direct swap if the holes are drilled for the new-style castings. If they're drilled for the old-style castings, then you'd have to fill the existing holes with epoxy and re-drill in the correct hole locations. But regardless, the blades themselves are interchangeable.
The rudder blades for the Tiger are a different profile, but they use the same rudder casting as the 17, so they should fit. However they wouldn't be class legal. They'd probably be fine for "fun" sailing though.
