It is currently Fri Jun 19, 2026 5:37 pm
 Post subject: tramps
PostPosted: Sun Jul 31, 2011 5:42 am
Thanks all for a great forum. I noticed yesterday I have a very small rip/tear in my newer solid mesh tramp. It's located near the front crossbar so I'm not too concerned about stress at this moment. It's about 3/8 inches long so it goes through about 3-4 mesh lines. Do any of you knowledgeable sailers have any advice on what and how I should address this? Thanks in advance for you time and help. Simie
 Post subject: Re: tramps
PostPosted: Sun Jul 31, 2011 11:04 am
Use some heavy duty thread and sew it closed. Thread must be UV resistant and its best if its the same color.
Sail # 10505 or 277
Image Image
PostPosted: Mon Aug 01, 2011 5:29 am
jmecky, thanks. Do you know if Hobie Cat heat welds small patches on the tramps like mine. If done properly, will the sew method work good. How strong would the web strands be that I'm sewing into/through?
Thanks again,
Simie
PostPosted: Mon Aug 08, 2011 1:43 pm
Is this a Slo Sails bias cut tramp? Solid, no center lacing? You go to them to get repair advice - even if it not theirs they may be able to tell you how to repair it or have a repair kit. Good Luck.
1984 Hobie 18
PostPosted: Mon Aug 08, 2011 1:47 pm
We do not do heat weld repairs. Once the material is dirty, at all, it shorts the sonic welder and burns the material.
I would use two small patches of vinyl and sew through both as a sandwich over the tear. An upholstery shop can do that as well.
PostPosted: Mon Aug 08, 2011 5:48 pm
"Solid mesh"? Do you mean solid vinyl or mesh vinyl? If solid vinyl and the tear isn't located in a high stress area, you might consider trying a product called "Tear-Aid", which you can find in the Hobie Parts and Accesories catalogue. I used it for a few minor repairs on my solid vinyl tramp and twelve months later the repairs are holding up perfectly. The key with this stuff is proper surface preparation. Use what they refer to as "Type B" (vinyl repair). I bought my kit at Eastern Mountain Sports for around $8.
PostPosted: Mon Aug 08, 2011 7:40 pm
I don't trust any glue in a dirty environment. Some may hold temporarily or seemingly permanently, but eventually will fail.
I did a major repair on my H14 vinyl tramp a few years ago when I was working at the local sail loft. Basically we stitched pieces of vinyl top and bottom, overlapping the damaged area by 2" on each side of the tear. This was a 2' long tear. So far it is holding up extremely well, and I recommend similar methods for repairing tears in tramps.
