It is currently Sun Aug 09, 2026 10:31 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Sep 23, 2011 10:14 am
New stuff is on the right [71301001 TRIM-LOC SEAL (TOP MOLDED)]. Glued version on the left.
PostPosted: Sat Sep 24, 2011 11:40 am
Cool. I suspect a lot of the water I get in the hull is coming through that hatch. This new gasket, sealed to the hull flange, should help that.
Do we just order this from a dealer? Is it in the catalogue? I'm going to be in the USA in a couple weeks and could have one shipped directly to where I'll be staying. So I can smuggle it home with me.
I'd pay an additional 44% import duty if I had it shipped to me here, on top of a $ 100 cost to UPS. Grrrr. Dang. dagnabbit. And imagine even stronger invectives, if you can.
http://2gringos.blogspot.com/
PostPosted: Tue Sep 27, 2011 8:12 am
Yes, Order from a dealer.
PostPosted: Mon Apr 23, 2012 4:33 am
After a longish sail from Cinnamon Bay on St. John, USVI, to Great Tobago and back (16 nautical miles in all, with 4-5 foot seas), it was very difficult to drag the TI up the beach upon our return. The hull had over ten gallons of water in it, and the root cause was the bow hatch gasket, which had come loose while at the island, and escaped notice. This is a potential safety issue; I am ordering the new gasket today, and will make a visual inspection before setting out in the future!
PostPosted: Mon Apr 23, 2012 5:18 am
Glad everyone is safe, Kevin. If you were further from land, this issue could have been a more serious emergency.
Hopefully, the new rubber Trim Lock will hold up better for us than the original ones installed at the factory.
Marc K
2010 Hobie Tandem Island
Boynton Beach, FL
PostPosted: Mon Apr 23, 2012 10:25 am
You do have a bilge pump right?
PostPosted: Mon Apr 23, 2012 10:56 am
What Tony said! And a big sponge. Both leashed somewhere (inside or out of the hull) where you can find them when you need them.
Don't leave home without them. :)
PostPosted: Tue Apr 24, 2012 5:27 pm
Seems like an ongoing concern, I searched “TI Hatch gasket” and found concerns for the past few years with recommendations for glues you might be interested in. I have a TI on order and any help from the Boston to New Hampshire areas on what to look for would be appreciated.
PostPosted: Tue Apr 24, 2012 8:19 pm
The new non-glued gasket should hold up better.
PostPosted: Tue Apr 24, 2012 9:21 pm
I used lacquer based (not water based) contacted cement and it's still stuck after 4 months. This contact cement we use to glue plastic laminated counter tops with.
"Riding The Island Wind" RIPIT (Tim)
'08 Red Hibiscus AI w/2013 replacement hull, Lovin' it!!!
'11 Golden Papaya AI (for a chap)
'11 Tarpon 160
'14 Pro Angler 12
