It is currently Sat Jun 20, 2026 9:22 pm
PostPosted: Wed Sep 28, 2011 6:58 am
Matt, I'm in the process of finalizing my Hull Only Revo 11 purchase.
Apparently, Hobie has changed the seat plugs and the seat plug on our 2009 Oasis seats don't work in the Revo 11. On my seat I use the seatback adjustable plug kit 81265101 (which works great in our Oasis).
Does Hobie have an after market seatback plug kit for the older seats, or will I have to buy another seat.
Dave
2009 Oasis
2012 Freedom Hawk Pathfinder
PostPosted: Wed Sep 28, 2011 9:19 am
I'm not clear on what you are trying to achieve. The new 2012 Revo will come with a new seat.
Seat pegs themselves are interchangeable from one seat to another. The 2012 peg system will not work in older boats. Older pegs will not work in a 2012 model hull.
We do have both older types of pegs available. You could buy a 2012 boat and downgrade the seat pegs to fit an older model boat. The expandable peg kit is # 81265101 (pair)
We do not have a kit to upgrade older boats to the 2012 system. Installation of the fittings into the hull is considered too difficult (requires tapping threads) and there is a potential of peg hole failure if done incorrectly.
PostPosted: Wed Sep 28, 2011 10:24 am
Lets try this again. :shock:
I have two seats in great shape from my 2009 Oasis.
I will be buying a hull only Revo 11 this week or next week. (I only need the hull as we have two mirages, two paddles, two cassettes and other gear.)
To avoid buying a new seat for my hull only Revo 11, are there peg attachments to fit and enable my 2009 Oasis seat to fit in my new Revo 11?
2009 Oasis
PostPosted: Wed Sep 28, 2011 1:40 pm
Yes. That we have. $7.50 (USD - 9/2011)
81276201 TWIST LOCK SEAT ADAPTER KIT
CONVERTS OLDER SEATS TO FIT A TWIST LOCK HULL
Includes 2 of each 81277001 Handle, 81245001 Roll Pin, 81276001 Twist Lock
PostPosted: Wed Sep 28, 2011 5:00 pm
Here is an installation sheet: http://static.hobiecat.com/web_uploads/ ... 276201.pdf
PostPosted: Wed Sep 28, 2011 7:29 pm
If you want to use your '09 seat for both boats, you can remove the 2012 peg inserts from the new hull by unscrewing them. Then your old seat pegs will work directly in both boats without having to convert them back and forth.
The better option IMO is to bite the bullet, buy the new 2012 seat for your new 2012 boat and keep it as a dedicated seat. That way you have enough seats to launch both boats with at least one Drive for each. This will accommodate grandkids, friends, or opportunistic strangers. Besides, if you ever sell one boat or the other, you won't come up short. 8)
 Post subject: Re: Roadrunner
PostPosted: Thu Sep 29, 2011 7:02 am
After sleeping on it, I came to the same conclusion: Bite the bullet and buy a new seat.
That way I can have two seats dedicated to our Oasis and one for my new Revo 11.
This will result in less hassle. Less hassle usually equals more time kayaking instead of screwing around with the hassles. :mrgreen:
2009 Oasis
PostPosted: Thu Sep 29, 2011 8:52 am
If buying a seat separate from the boat... order the seat plus the 2012 peg kit. We do not currently stock 2012 configured seats in our parts warehouse.
