It is currently Fri Jun 19, 2026 5:17 pm
 Post subject: Storing mast up
PostPosted: Wed Oct 05, 2011 5:14 pm
Should I put the step hinge pin in when it's parked on the trailor to prevent rotation an potentially wear on the rigging?
The ox is slow but the earth is patient
 Post subject: Re: Storing mast up
PostPosted: Wed Oct 05, 2011 7:37 pm
Personally I leave mine unpinned with the mast up.
Rather leave mast unpinned and free to move in strong winds whilst stored.
Richard Stephens
PostPosted: Thu Oct 06, 2011 5:50 am
I've never considered that before as I don't usually have the option of storing the boat with the mast up. However I think the suggestion has merit, saving wear on the base, step and rig. Though if the boat is left unattended you may want to figure how to secure a pin so it doesn't get 'accidentally on purpose' removed.
Chris
'88 H18SE Arís
PostPosted: Thu Oct 06, 2011 6:19 am
6 of one, half dozen of the other. How bout no stepper, tighten the shrouds a bit more?
PostPosted: Thu Oct 06, 2011 6:45 am
I would shy away from the pin and tie the mast still with the rotator arm if that concerns you.
2010 AHPC C2 #218
PostPosted: Thu Oct 06, 2011 7:47 am
Same here, I wouldn't bother with the pin. On my beach boat, I keep the rigging a little tighter than I normally would for day sailing. This keeps the mast from banging around and also prevents someone from pulling a pin since you can't get the pins to move without hanging some weight on the trap wire.
The rig is designed to rotate so I don't think you're hurting anything by allowing it to do so. If you keep the shrouds tight, the mast will pretty much stay un-rotated anyway. As long as it isn't slamming around, I think you're fine.
PostPosted: Thu Oct 06, 2011 5:30 pm
My boat lives on the beach. Pull the pin and keep the mast straight by using the mast rotator. Keep the rig tight. Replace the ball more often.
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
