It is currently Thu Apr 23, 2026 12:18 am
 Post subject: hobie 16 year
PostPosted: Tue Oct 11, 2011 2:41 pm
I bought an older hobie 16. Has Tequilla Sunrise sails. Hulls are white, but as I took off parts, I found several coats of paint covering yellow jell coat. Looking at the sail guide on here would make the boat 78. I tried lite sanding where the hull numbers should be but found that they have been refiberglassed. Are there any other ways to determine year of the boat?
 Post subject: Re: hobie 16 year
PostPosted: Tue Oct 11, 2011 3:54 pm
Carbon dating. I have a lab in Tijuana that will do it for 100 pesos.
Sail # 10505 or 277
Image Image
PostPosted: Wed Oct 12, 2011 4:16 am
The sail pattern is not always a good indication of age. A lot of the patterns were sold for more than just a year, some several years. Also, it might not be the original sails.
Closest you might get (aside from carbon testing), is era it is from.
Marc...
PostPosted: Wed Oct 12, 2011 6:02 am
Thanks for the info. I think I'll save the hundred peso's for now.
PostPosted: Thu Oct 13, 2011 11:01 am
There are some other clues, like if you have adjustor plates on top of your rudder castings, all Aluminum mast or composite tip, aluminum finish rails or black anonodized rails/mast, etc. but for the most part there have been so few changes, and none of them major, that it is hard to tell and doesn't seem to matter much if it is solid and well maintained.
Also, so many folks have retrofited newer parts on older boats that even the clues are misleading at times.
Enjoy it! Post a picture and we can tell roughly the era asuming it hasn't been modified much.
Welcome to the Forum! There is a ton of info here.
Steve
PostPosted: Thu Oct 13, 2011 12:53 pm
Thanks I purchased my first Hobie this year turbo 14, Bought the 16 2 weeks ago. Just trying to figure what year parts will interchange on the 16's.
