It is currently Thu Sep 10, 2026 12:23 pm
 Post subject: Traveller system
PostPosted: Mon Jun 12, 2006 11:35 am
Hi guys
My 14 Turbo currently has the old style traveller system that has the cleat attached to the traveller itself. This does not work well. I was wondering what parts I need to install a centre mounted fixed cam cleat. Any help would be great.
 Post subject: Traveler
PostPosted: Mon Jun 12, 2006 11:55 am
Wow... must be an early 70's boat?
You need a swivel cleat, mounting plate and an padeye strap.
Page 48 of the 2006 catalog
#50007 Swivel cleat
#1162 "pad" mount (includes mount hardware)
#11470000 Padeye (requires 2ea 6-4 rivets #8010181)
PostPosted: Mon Jun 12, 2006 1:02 pm
yea my boat is a 1978 one. The traveller system does not work at all. Is there any traveller car that has ball bearings that I install instead of the original one. Thanks
 Post subject: Car
PostPosted: Mon Jun 12, 2006 1:17 pm
Does your car have stainless rollers? The car # 105 is what works in your boat.
PostPosted: Mon Jun 12, 2006 1:58 pm
Hi
I don't think it had rollers at all, it was made of two plastic pieces held together by a metal sleave, i think
PostPosted: Mon Jun 12, 2006 5:17 pm
Matt - sounds like he had one of the original "Cat's Claw" travellers. Solid plastic slide (before roller bearing travellers were legal).
H14Turbo - when you get your new traveller installed, see how smoothly it works. Your old traveller might have damaged the inside of the track to the point where you might want to replace the track.
PostPosted: Tue Jun 13, 2006 12:31 pm
If you go with then new stuff, you will see a huge difference. If you want to save a little and get it used, I have a complete set up including the track, special rivets, traveler, swivel cam cleat (and base) and eyelet for the traveler line.
You can drop me a line if interested at [email protected]
PostPosted: Fri Jun 16, 2006 4:26 am
How is the cam cleat base attached to the rear crossbar. What tools are
need ed to attach it?
PostPosted: Fri Jun 16, 2006 6:46 am
The base attaches with one rivetat the back near the traveler track. The swivel cam cleat is attached to the base with two screws that go through the base and then screw into the beam.
You would need a rivet gun for the rivet and a tap set to tap the holes for the screws. You may be able to get by with self tapping screws, but you need ones with countersunk heads so they won't interfere with the swivel.
Also, on the traveler, if you have to replace that, you need countersunk stainless rivets and they run about a buck each. You also have to grind down the sides of the tip of your rivet gun so it fits in the track.
If you are keeping your track, you would only need to rerivet the last two rivets on one side. You need to remove them so you can slide the car in the track.
Hope this helps.
PostPosted: Thu Jun 22, 2006 7:26 am
Will the traveller #105 definitely fit on the old style traveller track?
