It is currently Fri Jun 26, 2026 1:49 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Dec 23, 2011 11:42 am
I am pretty sure that I am getting the aluminum one. I didn't specify but I traced it back to the creator that ended up hooking me up with a guy in CA from Hobie that had some of the originals.
PostPosted: Mon Jan 16, 2012 12:13 pm
Helo SW.
I left several emails for those guys in the AU without return. Do you have contact info for your source in CA? Cheers, BB
PostPosted: Tue Jan 17, 2012 7:26 am
Greg Thomas
760.758.9100 x204
www.hobiecat.com
Greg Thomas <[email protected]>
PostPosted: Tue Jan 17, 2012 7:27 am
I got my probe but need to fabricate a way to attach the transducer to the Ram mount.
PostPosted: Thu Jan 19, 2012 12:14 am
Salt Warrior wrote:
Greg Thomas
760.758.9100 x204
http://www.hobiecat.com
Thanks much. Keep us up to date on your progress.
PostPosted: Thu Jan 19, 2012 11:37 am
Hi Guys,
I'm new here and I just ordered a Pro Angler from ACK along with the Hobie single trailer, but I haven't received them yet.
Lowarance makes a special transducer mount that utilizes one of the scupper holes, but I don't know if it's appropriate for a Humminbird transducer or the Pro Angler kayak.
Here's a link to it on Amazon...
http://www.amazon.com/Lowrance-Kayak-Sc ... =8-1-spell
PostPosted: Sun Jan 22, 2012 9:54 am
check out Yakattack.com
I saw a picture of a transducer mount on a PA they have, might work for you.
PostPosted: Sun Jan 22, 2012 6:23 pm
Luther...you listening? LOL
I just need like a small, square piece of plastic that I can mount the transducer to the ram mount...too lazy to take pictures been fishing for three days.
PostPosted: Sun Jan 22, 2012 6:25 pm
OneLung wrote:
Hi Guys,
One of the guys from my local club just informed me that the Lowrance Scupper Mount kit would work for my Humminbird ducer. I thought it would only work with Lowrance stuff...I am going to check that out. My buddy is installing a Lowrance with that kit on his Revo. I will wait and see..
PostPosted: Sun Jan 22, 2012 8:08 pm
Hobie Team Member
Luther rigged up my PA for the Richmond, (VA) fishing expe this weekend and we used a prototype of the soon-to-be-available yak attack transducer arm. There are already several photos floating around FB and on Luther's site I believe. As soon as I can get a chance I will either copy a link here, or download some pics......
PostPosted: Sun Jan 22, 2012 8:44 pm
It's Marty right? Sorry I missed a chance to meet you. I was able to get a good look at your boat. Of course we left it with a lot of envy :) I saw that Transducer arm you had on your boat. Do you think the arm would cause some drag with that foam in the water?
2011 HPA
2006 Wildy Ride 135
2019 Hobie Compass
2020 Hobie Outback
PostPosted: Sun Jan 22, 2012 9:35 pm
I really like that Go-Pro mount!
PostPosted: Mon Jan 23, 2012 10:47 am
I have the homemade version of that going on right now. It is working OK. It is a temporary solution until I figure out exactly how I want to mount it permanent.
PostPosted: Mon Jan 23, 2012 10:55 am
I was wondering the same thing...you can see mine in a previous post is a small piece of aluminum. It causes some noise and some drag. The noise is minimal if I keep it perfectly straight in the water and the ducer is down enough not to cause gurgle. The drag is not very noticeable on a Hobie after you get used to it. When I put this on my Tarpon it was very noticeable. Kinda like the wind is way more noticeable on a paddle kayak than a pedal.
PostPosted: Mon Jan 23, 2012 12:53 pm
The Lowrance scupper 83/200 kHz Skimmer® transducer mount will work on the pro angler Compatible Scupper Hole Dimensions
Circumference: 1.5 in/3.8 cm max. | 0.95 in/2.4 cm min. Depth: 9.25 in/23.5 cm max. | 1.58 in/4.0 cm min.
