It is currently Thu Jun 25, 2026 7:01 pm
 Post subject: Pro Angler Trailer
PostPosted: Fri Jan 27, 2012 3:58 pm
I was getting a good many questions about the trailer so I threw this together:
http://www.youtube.com/watch?v=WPd5n83l ... e=youtu.be
 Post subject: Re: Pro Angler Trailer
PostPosted: Fri Jan 27, 2012 4:08 pm
Great stuff Tom! Thanks.
PostPosted: Fri Jan 27, 2012 6:10 pm
Ohh man!!! Continue the vid with the Whole Different Story :) Thanks for the vid.
2011 HPA
2006 Wildy Ride 135
2019 Hobie Compass
2020 Hobie Outback
PostPosted: Fri Jan 27, 2012 7:24 pm
That's a Mokai - a whole different take on a kayak. It will do things that no other kayak can, but you're back to having an engine, gas, etc. I'll do something on it later.
PostPosted: Sat Jan 28, 2012 6:25 am
Tom I like that set up. It's simple yet secure, good job.
Perception Caster and Proud owner of a 2012 Hobie Outback
PostPosted: Sat Jan 28, 2012 6:57 am
It's also self aligning - whether you push or pull the boats onto the pipe, they automatically center in the scupper troughs.
PostPosted: Sat Jan 28, 2012 7:34 am
Saw that. and the flex of the pipes helps that. I think you used 2" PVC? I have seen others with 4" . It seems the 2" would be stronger. Is it PVC schedule 40?
PostPosted: Sat Jan 28, 2012 1:52 pm
The smaller the pipe the better it will conform to the hull shape. However, if you go too small you end up having the boat hull bottom out on the support structure. 2-inch has worked perfectly. Yes, it's schedule 40.
PostPosted: Fri Feb 03, 2012 3:36 pm
Impressed with the trailer and the decked out PA. My question as a perspective owner is, with all the mounted gear on both port and starboard side rails, how do you get into the seat when launching and exit the seat when docking without snagging or breaking gear?
PostPosted: Fri Feb 03, 2012 4:08 pm
I hadn't really given it much thought because that stuff really isn't in the way. Not at all. If it is I sure haven't noticed it.
Unlike our other kayaks, used in rivers where we skin over and into the boat across the gunwhale, we're normally getting into and out of our PAs from a dock or bank. In other words, we're stepping into them, not crawling over the side where that stuff is mounted.
The stand up bar is also a great aid for getting into and out of the PA.
PostPosted: Fri Feb 03, 2012 4:46 pm
That makes sense now. Thanks
