It is currently Wed Aug 05, 2026 12:12 pm
 Post subject: 2011 Oasis foam question
PostPosted: Thu Feb 09, 2012 9:20 pm
Hello, I purchased a used Oasis. It has three pieces of foam.
One is located on the right side with the front edge just at the back of the front hatch and it's wedged up nice and tight along the top side of the hull. There is not a matching one on the left side. Is there supposed to be? :?:
The other two pieces are loose in the back half of the craft. They both have rectangular shaped front ends and both are tapered on the rear ends. Where are these supposed go? :?:
Thanks in advance for any help...
William
-William
(La Porte, TX) [Hobie Oasis 2011]
PostPosted: Fri Feb 10, 2012 11:26 am
I will have to check my 2011 Oasis when I get home. I have not gone looking for it but I know there is some floatation foam in there somewhere. it sounds like the foam in yours may have gotten knocked lose. The point of the foam is if your craft was totally flooded inside and out it will still stay on the surface (barely). Where the foam goes is not critical as long as there is some in the front and the back and it is securely attached. Maybe someone more savy with mods can suggest a way to glue it down.
PostPosted: Sun Feb 12, 2012 9:21 am
Thanks TalonDJ,
I took a quick look a the manual and didn't find anything for it. I wasn't sure where to wedge the two loose pieces towards the back-end -- I was wanting to make sure that I didn't interfere with the rudder and controls...
I was also curios if there was supposed to be two pieces up front.
-William
PostPosted: Sun Feb 12, 2012 1:53 pm
Is it not packing foam from when the boat was first delivered ?
PostPosted: Sun Feb 12, 2012 4:51 pm
I'm not sure if it's packing foam, I bought it used (it was a demo). I guess I will try calling a factory rep.
-William
PostPosted: Mon Feb 13, 2012 12:55 am
It's flotation, now installed in all the kayaks. It's not glued, but wedged in and in your case, has come loose. I'll try to grab a photo of where it goes this week if no one has a picture for you in the meantime. 8)
PostPosted: Mon Feb 13, 2012 5:44 am
That would be great! Thanks!
-William
PostPosted: Mon Feb 13, 2012 11:03 pm
Two in the rear half between the aft seat, and jammed into the rod holder; one each side tucked high. Stay outboard of any lines and cables.
(looking forward, from stbd side rear hatch; rear of flotation seen on extreme right outboard of rod holder)
(looking aft from rear cockpit hatch: port flotation seat scupper in foreground, extending back to rod holder)
One in the front half, forward of front seat from large bottle holder forward, wedged in to side rails(?) Not pictured.
One of mine had worked loose. Just tuck them in the best you can so they aren't drifting around the interior. 8)
PostPosted: Tue Feb 14, 2012 2:02 pm
I think they're there to provide extra rigidity to the sides of the yak... and maybe some floatation in case it fill up with water (?)
2011 Oasis - Lunalilo Express
2012 Revo 11 - Lunalilo
PostPosted: Tue Feb 14, 2012 9:19 pm
Roadrunner,
This is exactly what I needed. I sure appreciate you taking the time to clear this up for me!
AWESOME!!
-William
