It is currently Sun Aug 02, 2026 12:39 pm
 Post subject: Cam locks on rudders
PostPosted: Thu Jun 24, 2004 5:01 pm
Pretty new to Hobie Cats. Is there an easy way to move the cam locks on the rudders? It seems awfully difficult to move them to lock the rudders in the up and down positions.
Also, my starboard rudder doesn't want to lock up. It seems the cam piece is a little too big and the rudder bumps it, and the cam won't allow the rudder to travel far enough.
Any thoughts/ideas are appreciated.
Jeff Hall, Lakewood, Ohio, USA
 Post subject: Re: Cam locks on rudders
PostPosted: Thu Jun 24, 2004 7:33 pm
If you take the rudders off and turn them upside-down, you'll see that there is a really big plastic screw up in there. I guess many peoples' don't turn easily but I had no trouble adjusting mine. You can tighten or loosen the cams with that screw.
Dunno about that one. Sorry!
Jim
PostPosted: Fri Jun 25, 2004 5:08 am
It sounds (without seeing a photo), that the holes in your rudders might be drilled in the wrong place.
Try using the Hobie template (located here) to check the placement of the holes.
The cam and plunger system should be taken apart periodically, inspected, lubed and reassembled. Use sister screws to replace the rivet that the cam pivots on. That way, you can replace the cam easily if it breaks. Smooth off any rough edges where the plunger and cam go together.
When everything is working right, the rudder will lock down with a distinct "snap."
PostPosted: Fri Jun 25, 2004 9:51 am
Also review our FAQ post about cams...
http://www.hobiecat.com/community/viewtopic.php?t=467
 Post subject: jeff
PostPosted: Thu Jun 15, 2006 2:02 pm
hey jeff do you still live in lakewood
mike
