It is currently Sun Jun 07, 2026 5:17 pm
 Post subject: TI prototype jib size ?
PostPosted: Tue Feb 21, 2012 4:14 pm
I was told there was someone from the Hobie company sailing a TI at the Everglades Chalenge race, the boat had a prototype experimental jib.
Does anyone know the measuments and area size of this jib?
PostPosted: Tue Feb 21, 2012 8:12 pm
Gil,
The Hobie engineer/designer Jim Czarnowski can be seen in a post of mine.
http://www.hobiecat.com/forums/viewtopic.php?f=71&t=34266
He is sitting on a Hobie AI tandem and you can see a furled jib. The photo was taken at last year's EC. My guess is he will be at the EC2012 (Mar 2-3 in Ft Desoto State Park) and will probably be sporting a jib again. Are you planning to be there?
PostPosted: Wed Feb 22, 2012 5:25 am
I had a jib on my TI last year. I used a Newport 16 jib that fit very well. You can probably look up the dimensions on line. Unfortunately i sold my Newport. Don't forget to use some kind of stays and only in light weather. The mast support will get overloaded...
Look 6:11 minutes into this video...
[youtube]http://www.youtube.com/watch?v=BP8y7UOnYw0[/youtube]
Paul
DogsLife
2011 Adventure Island
PostPosted: Wed Feb 22, 2012 5:21 pm
Keith I do not plan to be at the EC, the reason I ask is because I have a sewing machine and planing to make a jib for use in light winds as suggested by Paul. I have a good idea for a rotating mast top device for the jib forestay.
I guess the size of the TI jib prototype is a well kept secret. I will look up the jib on the Newport 16 but having the Hobie jib size would take out all the guess work. :?:
Gil
PostPosted: Wed Feb 22, 2012 5:37 pm
Chekika wrote:
Gil,
I have friends in the EC race, perhaps some jib espionage is in order :wink:
PostPosted: Wed Feb 22, 2012 6:37 pm
wow I just saw your super cool video for some reason I could not see it before , any how the jib looks awesome, thanks much for sharing it.
Gil
PostPosted: Fri Feb 24, 2012 5:42 am
I actually made a new jib for my TI out of a old main sail that I had. It is not as nice as the Newport Jib because the main was slightly blown out. I do find it easier to cut down a old sail instead of starting from scratch. You already have the curvature built in. Because the new sail has more draft it is a nice down wind sail but does not point well. For the EC I will use my AI this year. I found a small nylon jib on E-Bay that I will use in down wind light air.
Paul
DogsLife
PostPosted: Fri Feb 24, 2012 8:55 am
What Size is the Jib you made ?
thanks.
Gil
PostPosted: Fri Feb 24, 2012 7:12 pm
I got my dimensions right off the boat. Stretched a rope from the mast attachment point to the bow. Then I estimated the leech and foot based on where I wanted the clew, slightly aft of the mast. Then I transferred it to the old sail that was larger than needed. I fit the sail triangle on the old main sail for the best cloth pattern. Make your dimensions slightly less than measured. The sail will stretch and the mast will bend. Other thing to remember is that the luff and leach can not be a straight line due to the sag. I used a long pice of molding as a batten to mark a slight inward curve. You Tube has some good sail making Videos: this is just one of the series;
[youtube]http://www.youtube.com/watch?v=GD8z720Q7fY[/youtube]
Paul
DogsLife
PostPosted: Fri Feb 24, 2012 9:04 pm
ok but what is the size of the jib
thanks
PostPosted: Sat Feb 25, 2012 3:59 am
I thought he mentioned that you measure from bow to masthead, and then from bow to mast base, and then build in slight curvature in the luff and leach, making your dimensions slightly less than measured. They aren't numbers, but they seem pretty descriptive to me. I would add that you want the clew to be about 3 feet above the base of the mast to enable a fair lead for the sheet back to midships
PostPosted: Sat Feb 25, 2012 7:18 am
Is the tape to reduce the hull flex around the hatch opening when using your jib?
PostPosted: Wed Feb 29, 2012 9:55 am
Paul, again I had not seen your reply when I ask you about the jib size.
The video is very helful I'm working on the jib right now. thanks much
Gil
