It is currently Sat Jun 20, 2026 12:02 am
 Post subject: Mast Caddy Help
PostPosted: Wed Mar 28, 2012 1:39 pm
I was reading a post by Harry Murphey commenting on a block to make the Mast Caddy fit better on the rear cross bar. I have this issue, when clamping down on the crossbar the blocks get very crooked and I dont trust it to stay on when trailering so I wrap a bungee cord around the base and connect to my tramp lacing.
Since I dont have the block they came out with is there a better solution to keeping the caddy in place. Though I would say I have made a couple of 7+ hour trips with no issues. Just not sure I trust it.
1984 Hobie 18
 Post subject: Re: Mast Caddy Help
PostPosted: Wed Mar 28, 2012 4:31 pm
Hi,
I just went out and measured the "block" that was supplied w/ my mast caddies ... (I have two, one for my H18 and one for my P19MX ...) The material used for the block is 9/16" thick X 3" long X 1 3/8 wide. The material is black plastic ... but I don't think the material matters all that much ... you could use a piece of wood, plywood, plastic, etc ....
Now so I wouldn't loose the block, I drilled a small hole in the block and another small hole in the bottom "crossbar clamping" section and using a 1' long piece of batten string as a "safety line" tied the "block" to the bottom section so that I wouldn't loose the block.
For the H18 the "block is installed horizontally ... for my P19MX w/ it's much thicker rear crossbar you place the "block" on edge ..... then just tighten down on the knob .....
I have been thinking of drilling a small hole in the threaded bolt and installing a cotter-pin or clivis ring so I can never loose the knob .... but it has never loosened up .... so that maybe "overkill" ....
It sounds like you do the samething as me w/ a bungie cord wrapped around the mast caddy and pulled forward, attaching to the center lacings. My 3/8" bungie is long enough that it attaches up near my forward crossbeam ....
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
PostPosted: Thu Mar 29, 2012 4:48 am
What is this block supposed to do? I threw mine away thinking it was something the previous owner had jury rigged.... The block seemed to prevent the clamp from squeezing down tight on the cross bar, I think it works better without it.
PostPosted: Thu Mar 29, 2012 5:48 am
Not sure I'm understanding the concept behind the block. Does your Caddy look like the one below? If yes, where exactly does the block go? As they say, a picture is worth a thousand words.
PostPosted: Thu Mar 29, 2012 6:52 am
Thanks for the pics. Here are mine. I reversed the clamp brackets - this made mine stay on better. But it looks like you have some type of block between your clamping blocks. This must be what Harry is talking about. You can see how uneven my blocks are without it.
1984 Hobie 18
PostPosted: Thu Mar 29, 2012 12:34 pm
The block does keep the clamping surfaces even. I had one of these on a 16 and it was the best caddie I ever had, should have never sold it with the boat. I never used it on an 18 but with even clamping it should work great. Just screw it down tight every time, i also used a backup bungee still do with what ever I use to hold a mast.
Bodhisatfa
PostPosted: Fri Mar 30, 2012 1:35 pm
I have the same mast caddie. I just use a couple of used rudder cams lying flat inbetween the the sections and tighten down. This keeps the pieces straight and level.
ADDICTION
1989 HOBIE 18 SE/sx wings
HOBIE ALTER SIGNATURE MODEL
PostPosted: Wed Apr 04, 2012 6:47 am
FYI, I just posted my used Mast Caddie for sale in the Classifieds area. The clamp has been modified to correctly fit the Hobie 18 rear crossbar.
2007 Hobie Tiger
