It is currently Fri Jun 19, 2026 9:04 am
Post new topic Reply to topic  [ 1323 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 89  Next
PostPosted: Wed Apr 11, 2012 3:50 pm
Larry, that tiller extension method is an outstanding example of the reason the KISS principle is a winner. Simply brilliant.
PostPosted: Wed Apr 11, 2012 4:14 pm
Thanks Tony, But KISS is also another work for lazy and in a hurry. I want most of the things too serve duel purpose. I have some bench seats that I got for ball games at the high school but never used, they will not last long in salt water but at least I'll get some use out of them. I will strap them under the back strap for the boards, and see how long the ratchet back rest will last this weekend. I'll have the gopro on and the other camera so more next week.
“Remember life is short- eat dessert first.”
The world is 70% water – So that means we should spend 70% more time sailing than mowing lawns!
Larry
PostPosted: Wed Apr 11, 2012 8:02 pm
Thanks Tony, But KISS is also another word for lazy and in a hurry
Don't be so modest Larry! All the other solutions I have seen for attaching a tiller extension have been more complicated/pricey. Yours, on the other hand, could easily be swapped to either tiller on a TI, is easily adjustable, and just as importantly, easily maintained (by swapping in some new cord).
Good luck with the deluxe seating arrangements too :)
PostPosted: Wed Apr 11, 2012 8:12 pm
You want simple? :wink:
20mm conduit offcut, 2 rivets (one each side), bungee, heatshrink, rubber handle.
OK.... I overdid it with the heatshrink and the rubber handle and I probably could have got away with one rivet.
Thanks for the idea Larry! :)
PostPosted: Wed Apr 11, 2012 11:35 pm
NOHUHU wrote:
NICELY DONE! Extra points for the rod holders. 8)
I was looking at cable raceways and the like for just such an idea, but FRP seems to have a higher load rating. Going with only 3 slats, they need it...
Looking forward to more info on assembly options, weight and performance.
Great first post!
Thanks NOHUHU and to all for your contributions. They helped me decide on my haka version.
Here are some details: each haka weighs ~13 lbs. I used bike tire inner tube on each channel to protect the aka from getting scratched. The rubber tube also prevents the haka from slipping. The spacers are made of 3/4"x1"x12" HDPE (cutting board material) screwed (#8 brass machine screws) on the channels. Painted to match the hull color. The bench flexes a bit which I guess gives better performance. When I sit on the center, where the AI is on solid ground, the haka sags about 1.5"; granting I weigh 165 lbs. Total time to finish... 7hrs including runs to the hardware store. Will I do it again? Maybe. It was challenging but I had a great time building it.
http://flic.kr/p/bxQjHf
PostPosted: Thu Apr 12, 2012 1:25 am
Tony, Thanks. I'll get some pictures of the seating and any crashes this week end. I remounted the mounts for the gopro last night so will have it running this weekend.
Stringy, That looks great! Very well done. Nice and light also.
Larry
PostPosted: Sun Apr 15, 2012 3:21 am
Saturday 4-14-2012
Steve and Christina helping me test the boards. Tiller extension failed too weak to pull to you, so back to the drawing board with it. Boards on the other hand were a great success, but you be the judge.
http://img16.imageshack.us/img16/3481/21108224.mp4
1. New GoPro Mount.
2. Tiller Extension.
3. ?????????
Larry
PostPosted: Sun Apr 15, 2012 3:53 am
I think a stick with a carabiner and a hole in the tiller handle would make an OK tiller extension. That's my plan anyway. First I want to build some foam core Hakas.
PostPosted: Sun Apr 15, 2012 4:45 am
I used that system for years and it works fine with the old style rudder lever.
It's not so easy to implement with the new style rudder lever, so I switched to using RAM fittings.
The connection works very well, but I have had to replace the ½" dowel handle with ½" copper pipe. The problem is that in their wisdom, Hobie has the new rudder lever moving in a more vertical plane than the old one, which moved in a near horizontal plane. That means that instead of just pushing and pulling on the tiller extension, you need to exert some sideways force, so you need a stronger handle. That's also probably why Larry's bungee loop extension proved too weak. I'm sure it would have worked fine on the old style lever.
I must say I'm mystified why Hobie provided a threaded hole in the new rudder lever, presumably to accept a future tiller extension, then re-oriented the lever so it is much harder to control with a tiller extension.
PostPosted: Sun Apr 15, 2012 7:45 pm
larryhts wrote:
Saturday 4-14-2012
Larry,
You might want to try a better quality HD bungee. I was happy with the way the bungee tiller performed. I am using a fairly stiff 3/16" bungee. There was a little bit of stretch but I found it manageable on the AI. It was only in light winds and I still have the original TnS rudder. I will try it on the TI this week.
The next simplest solution looks like Chrisj's snap hook. An eyebolt in place of the knob should work. Problem here is that it's hard to get a SS imperial eyebolt to fit. I'll keep looking.
BTW -Have you tried the R3 setting on the GoPro? You get a much wider field of view and less "jello wobble" in fast moving scenes.
PostPosted: Mon Apr 16, 2012 1:52 am
Larry, we have tried all sorts of articulating joints and threaded connection on the tillers. Presently I just use a good quality plastic cable tie around the base of the new tiller knob. Just tighten it to the perfect size and clip the end. Works and rotates perfectly.
At the end of the sail, I just cut it off.
The Wind Is Your Friend...
PostPosted: Mon Apr 16, 2012 1:57 am
tailwalker, Great info. Sounds like it's just slightly heavier than wood.
What was your total cost of materials?
PostPosted: Thu Apr 19, 2012 6:29 am
Yup Nohuhu. It gets quite heavy hauling the AI with the Haka and all my
fishing gear on it. But I get rewarded once on the water.
Sorry, I did not keep tab of the cost. But it's quite pricey.
PostPosted: Sun Apr 22, 2012 10:31 pm
I'm considering going with some Safe-T-Span grating. Looks like I can get a 2 ft x 6 ft piece from Grainger for around $250. Not too bad compared to tramps, or even compared to lumber and stainless hardware when you factor in build time.
Cut it in half lengthwise then bungee it to the amas. Highly resistant to sun and salt.
http://www.grainger.com/Grainger/SAFETSPAN-Grating-4AUC3?Pid=search
http://www.fibergrate.com/frp-products/pultruded-grating/safe-t-span-pultruded-gratings.aspx
Best part is, it comes in yellow! Second best part, I might be able to use them as a type of sand ladder for getting unstuck on the beach.
If I decide to use it, I'll be sure to let you know how it turns out.
-Chris
2015 TI
2009 AI (sold)
Lake Travis, Ladybird Lake, Rockport/Aransas/Padre Island
Texas, USA
PostPosted: Sun Apr 22, 2012 10:58 pm
I was just looking at the all the FRP profiles and was checking these out. Those are the I-beam grates, and they make lighter versions too.
At half their price I would do it for sure. Right now, I'm in sticker shock... :cry:
