It is currently Sat Aug 08, 2026 8:58 pm
PostPosted: Thu Apr 12, 2012 6:50 pm
[youtube]http://www.youtube.com/watch?v=gj9GuDvieFs[/youtube]
I've had a number of people ask me about my trailer, or about my sail tube, and a few people doubt that I can get the Bravo from trailer to sailing in about 5 minutes. Hopefully this post will help answer some of the questions.
First the trailer. I had the trailer custom made for the Bravo. The bunks are removable, and I could re-work it to fit something like a Wave if that's the direction that I choose to go in the future.
I chose not to use a mast stand as the Bravo has the permanent tripod built into the boat, but after trailering a few times with the sail in the sail bag, and up on the tripod, I noticed some wear on the sail bag. The solution was to put the sail into a 6" pipe so that when it is tied down, it has no pressure points at all. Once I got the 6" pipe, I didn't want to place all that weight on the tripod, so I made a small "T" out of black PVC. The bottom sits over the ball that holds the sail in place, while the top fits into the top of the tripod. I bought a rubber collar to keep it from damaging anything if it moved around.
To secure the pipe, I thought of many options. There are probably better options than what I chose to do, but I decided to drill through the pipe, and put straps right through. To me, this was the simplest and most secure way that I could think of to attach the pipe, as well as keep the sail in a safe place with no screw ends or anything sharp protruding in towards the sail.
I glued all of the seems of the pipe and back end of the pipe, but also placed several UV resistant Zip Ties through the seams. My logic was that if the glue ever failed, I would have the zip ties hold things in place for the remainder of the trip. The glue isn't likely to fade slowly, it's likely to give way all at once (if it fails. I doubt it will) I plan on replacing the Zip Ties yearly, or as necessary if I notice wear.
So here are a few pictures of what I've got, and the video at the top to show how simple it all is.
I can go from trailer to water in about 5 minutes.
The side view, with everything secure.
The rear of the trailer. Plenty of reflective tape!
This piece mounts where the sail usually goes, and takes the weight of the Sail Tube with the sail inside.
This is how I ran the straps through the Sail Tube
Each piece of the sail tube is glued together, but the Zip Ties are insurance if the glue ever fails
The next two pictures aren't exactly how I secure the sail, but it will give you a rough idea of how things work.
This picture shows how the rear of the sail tube is secured. It rests on the boat, so this strap just keeps it from moving side to side, and acts as insurance if something fails on the front end.
This is a picture of the straps that hold the boat to the trailer by running through the scuppers and down to the trailer. You are looking at the deck of the boat where you would sit. Using a continuous loop, is better than using straps with hooks. If the hooks loosen, you lose the boat, this way, you can afford to have the straps loosen, but they would have to break right through for me to lose the boat.
This shows the continuous loop running through the trailer, under the bunks which hold the hull.
Feel free to ask questions if you have any!
PostPosted: Fri Apr 20, 2012 1:50 pm
Thanks so much, still looking for a really good deal! Hopefully ill find one before the summer starts :D
Liamr
2008 Bravo
PostPosted: Sat Apr 21, 2012 10:24 am
I was out yesterday. Summer already started. :)
PostPosted: Sun Apr 22, 2012 4:12 pm
Lucky you! It's still a bit too cold down here in NB...
I have been watching catamaran videos for about a month now...haha can't wait to take it out!
Mat
PostPosted: Mon Apr 23, 2012 8:31 am
To be fair, they're calling for snow today. :roll:
PostPosted: Mon Apr 23, 2012 8:55 am
Same thing here!
Have you been sailing for a while? I'm pretty new to this, got my first boat (bravo) last summer and I am still learning...pretty easy to pick up but to pick up and master is two different things :)
Mat
PostPosted: Mon Apr 23, 2012 9:06 pm
I've only been out once. I held off early in the year when the air temperature was great, but the water temperature was still dangerous. I went out last week because we had a 20 degree Celsius day, and I knew this week was going to be cold. I would have been out more, but I'm under doctor's orders to rest a minor injury for another few weeks. Luckily I didn't re-injure things the other day! (My wife would have killed me!)
I sailed a little bit as a kid, but bought an Adventure Island which really got me back into sailing. I bought the Bravo because I wanted to move to a more traditional boat. I'm still trying to decide if I'll move to a Wave or a Getaway next, but I ended up with a Bravo because someone was selling it for a ridiculously low price. It's been a great boat. Much better performing than I had thought it would be.
I hear you about the easy to pick up, difficult to master. I always compare it to golf. Anyone can sail a boat like this, but it takes some practice to really sail it well. It's a lot of fun though!
