It is currently Tue Aug 11, 2026 9:08 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 05, 2012 4:00 pm
TDK wrote:
atavuss wrote:
I used 4 Scotty clamp on rod holders, 2 on each side rail next to the seat. one rod holder has a Scotty fishfinder mount which is attached to a Mad Frog Liberator mount with a transducer arm attached. I use a Hummingbird 788ci combo FF/GPS. I use a 10 amp 12 volt battery which is inside a waterproof plastic box sourced from Walmart. one rod holder on each side has a Scotty rod holder with a 12" riser to hold rods while trolling. one rod holder is empty and I put my pliers in it that I use to remove hooks. works great, everything is easy to see and use, nothing is in the way and no holes were drilled anywhere in my PA. I did not want anything on the mounting boards because they would be in the way when getting in and out of the PA.
pictures are halfway down in this post:
http://www.hobiecat.com/forums/viewtopic.php?f=78&t=33618&p=134775#p134775
Hey atavuss,
How did you mount your Humminbird transducer to the Liberator arm? I have a 385ci DI and I'm not sure teh best way to make that attachment. FYI - your picture link in presious posts seems to have gone awry.
Thanks!
TDK
The Humminbird mount is screwed right to the Liberator arm. the Liberator mount is then screwed to a Scotty FF mount and the entire unit slides into the Scotty rod holder mounted on the side rail.
PostPosted: Sat May 05, 2012 8:51 pm
What will you do if you ever have to paddle? Are going to sit on your front hatch and row like a rowboat? :cry: :(
Steve Valerga Jr.
DV U.S.Army Airborne
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Sun May 06, 2012 6:56 am
The only time I paddle is when pushing away from shore. I only have the FF in (I don't put the rod holders in until I am away from the shore and I have the mirage drive in). I am able to paddle with the FF in, I just have to be careful and reach a little more on that side, it does not take many paddle strokes to get far enough away from the shore to drop the mirage drive in. When I beach the PA I just get enough speed up to coast onto the shore, don't even need the paddle then.
