It is currently Wed Aug 12, 2026 12:56 am
PostPosted: Mon Apr 23, 2012 8:21 am
Here's what I did. No slipping or flex at all.
PostPosted: Thu Apr 26, 2012 9:46 am
You can also get a piece of pvc from Grainger and cut it to use as a shim. Cost is about 4.50 for 3'.
Works great.
PostPosted: Sun May 06, 2012 11:35 pm
On the scotty rail mount there are 2 1/4-20 set screws in the bottom, I took them out and put 1 inch ss 1/4 -20 bolts in and tightened works just fine.
you hookem and i will fry um
PostPosted: Mon May 07, 2012 8:05 am
redgrappler wrote:
I purchased Scotty Rail Mount Adapters for my scotty rod holders. I wanted to move them form the mounting boards to the rail. I purchased the Scotty 242 adapters for 7/8 and 1" round bars. When I went to install it it looked like the adapter did not fit. I was unable to get the bar to touch the curved section of the adapter. Did I purchase the wrong size? What is the diameter of the PA Grab Bars?
http://www.scotty.com/fishing-gear-equipment/rod-holders/rail-mounts.htm
These will work fine. All you need to do is use 10/32" bolts instead of the supplied 1/4-20 bolts. The smaller diameter bolts will provide the clearance necessary to fit around the hand rail bar.
PostPosted: Tue May 08, 2012 4:48 pm
The Scotty #245 clamp on mount might be easier. You will need to add a thin shim between the rod holder and side rail, I used a piece of 1/8" thick rubber. Bicyclye tubes are about the perfect thickness.
