It is currently Sat Aug 08, 2026 4:49 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Slot
PostPosted: Thu Jul 06, 2006 10:41 am
It is very typical for sails to pass down below the slot opening, so that is no a critical issue. Some wear is expected.
To get the downhaul tight you can try sheeting hard while adjusting downhaul. Downhaul, then sheet and downhaul while the sheet is tight.
There are multiple holes the mainsheet can be attached in the sail's clew. You mat be pulling the sail too tight aft and out of the slot. Perhaps try attaching to a hole further aft in the clew plate. Another idea is to tie a loop of line around the mast and through the downhaul grommet to hold the tack tighter to the mast and in the slot.
PostPosted: Thu Jul 06, 2006 12:19 pm
Matt.....i have been using the center hole on the clew to attach the main block,,,,what/when should i be using the other holes?? I am also thinking of attaching a block/cleat for the downhaul for fast adustments under sail...anyone do this??
 Post subject: Adjustments?
PostPosted: Thu Jul 06, 2006 2:51 pm
Adjustments?
Lower / forward hole for more outward (outhaul) pull on the sail foot. Placing in the aft hole would make the sail more full, forward hole makes it more flat.
The H16 now uses a 6:1 downhaul for easy on-the-fly adjustments of downhaul. This is a kit that would fit the Getaway... 6:1 Downhaul #2089 shown on page 27 of the catalog.
PostPosted: Thu Jul 06, 2006 5:15 pm
I liekth your ideas Matt. I will try sheeting in then pulling the downhaul tighter, that will also put the opening at a freash spot in the luff. Your other idea about tieing a line around the downhaul line is great as well, I will have to try it. That idea did how ever lead me to another question, what is the bungee on the mast for?
 Post subject: Bungee
PostPosted: Thu Jul 06, 2006 11:13 pm
That would be a "tangle preventer". The idea is to keep the jib sheets from tangling around the base of the mast.
PostPosted: Fri Jul 07, 2006 5:17 am
so in..say...15-20K of wind, sailing solo, where would u attach the block to the clew?
 Post subject: Forward
PostPosted: Fri Jul 07, 2006 11:03 am
Forward for more "outhaul" and a flatter sail. Travel the main down the track a little too if the boat flys too much and you constantly have to sheet out. Further out on the traveler allows for a tighter mainsheet and therefore a flatter sail = faster. Even upwind.
PostPosted: Sat Jul 08, 2006 8:04 am
so how is the tangle preventer supposed to be rigged?
PostPosted: Sat Jul 08, 2006 10:06 am
Authorized Hobie Dealer
the pad eye where the jib sheet ties off to, clip it there on each side, this will make a triangle thus keeping the jib sheets from wrapping around the base of the mast and tangling.
Brad Stephens
www.sunjammers.com
Hobie Division 15 Chairman
Authorized Hobie/Vanguard/Hunter Dealer
Panama City Beach, FL
 Post subject: Thanks mark
PostPosted: Sat Jul 08, 2006 2:24 pm
Thanks for the suggestions Mark. I especially like the one of putting a line around the downhaul rope and lashin it to the mast thereby reducing the pull outward on the portion of the sail luff that is extending down into the open slot. I will do that and also take advantage of changing the location that my mainsheet is hooked into the clew. Thanks for the suggestions.
Randy
2006 Hobie Getaway
PostPosted: Mon Jul 10, 2006 12:36 pm
wait, connect one end of teh bungie to the pad eye on the port side, stretch the bungy around the mast and hook it to the stbd side pad eye?? anyone have a pic?? am i confused?
PostPosted: Mon Jul 10, 2006 12:54 pm
you can see it on page 10 of the assembly Manual, I also think it is in the rigging video
http://static.hobiecat.com/2010_archive/support/pdfs/getawaymanual.pdf
Brad Stephens
www.sunjammers.com
866-sun-jamm
PostPosted: Mon Jul 10, 2006 1:36 pm
i see it in the pic, lower left pic page 10..got it, thanks!!
