It is currently Thu Aug 20, 2026 2:58 pm
 Post subject: Furling Kit for Revo
PostPosted: Thu May 10, 2012 8:53 pm
I want to build or buy a furling device for mast on my Revo. Any suggestions? I have the standard sail kit and furling by hand is a drag! Please advise.
Thanks....
 Post subject: Re: Furling Kit for Revo
PostPosted: Fri May 11, 2012 8:09 am
I did a search and found this older thread where another user built one himself.
viewtopic.php?f=32&t=7740
PostPosted: Fri May 11, 2012 3:22 pm
Can't buy one, ya gotta make one. Mine is similar to the one shown in Jbernier's link. Pretty easy to make if you know which end of the screwdriver to hold.
Southwest Hobie Island Club
PostPosted: Fri May 11, 2012 4:13 pm
That was a very early mod which is simplified here:
viewtopic.php?f=32&t=8455
Revo_1756 simplified it even more here:
viewtopic.php?f=32&t=34749
You may also want to check out Halibu's mod mentioned in the thread. It seems popular with many users, but I haven't tried it.
PostPosted: Mon May 21, 2012 7:12 am
Thank you!
PostPosted: Mon Jun 11, 2012 5:56 am
On my 2011 Outback, I was able to utilize the exsisting bolt holes on both front sides of the Yak. (The rudder up and down lines)
1. Purchased the Hobie Anchor kit and utilized the included Harken Blocks.
a. Had to make the bolt holes in the Harken block a tad bit larger to fit the exsisting bolt size.
b. Purchased a 1.5" bolt/same width as the existing ones.
c. Make sure you only undo one bolt at a time!
Wala- works flawlessly!
