It is currently Sun Jun 21, 2026 12:44 pm
PostPosted: Fri May 11, 2012 12:16 pm
The jib hank on my Hobie 16 jib sail does not fit properly on my new plastic-coated forestay. It needs to be slightly larger to accommodate the slightly larger diameter forestay. Does anyone know if larger jib hanks are available?
PostPosted: Sat May 12, 2012 9:00 am
Just drill it out! If it breaks, it breaks. No big deal.
PostPosted: Mon May 14, 2012 11:34 am
Or remove the forestay coating!
Jerome Vaughan
Hobie 16
PostPosted: Mon May 14, 2012 8:59 pm
I had the same problem and I used a round file to make it a bit bigger, seems safer than drilling.
72 H16 and its white now
PostPosted: Tue May 15, 2012 6:52 am
Thanks very much. Using a round file seems like the best plan.
