It is currently Thu Aug 20, 2026 3:37 pm
 Post subject: Opening holes
PostPosted: Sat May 26, 2012 4:48 pm
To install the jib kit, the instruction calls for you to separate trapeze attachment rails. I notice these railed were attached with screws and also sealed with silicon sealant (goo). If I did install the jib cleats (which mean separating the rail making the sealant goo useless), would I need to re-goo the rail as I screw it back in, or is it safe just to leave it without sealing it? Thanks for all your help,
-B.
 Post subject: Re: Opening holes
PostPosted: Wed May 30, 2012 5:17 pm
You will be fine. I don't recall us using sealant there.
