It is currently Wed Aug 12, 2026 10:03 pm
PostPosted: Tue Jun 19, 2012 2:22 pm
I recently competed in the 2012 ORC put on by NWKA and did very well. I spent 3 days out on my PA and bloodied it up pretty well. Because I was camping, I could only hose it down a little between days and it was 2 days sitting before I could try to clean it. I took it to a car wash and used the pressure wash and still find my rear deck stained from the blood and Cabezon upchuck. While tattoo's are fine on me, I would like my PA to look clean.
What is the best method to remove stains from the PA? I am going to try Marine Simple Green and a brush this afternoon, but thought I would ask the group.
Thanks a ton.
PostPosted: Tue Jun 19, 2012 5:27 pm
bleach or soft scrub
PostPosted: Tue Jun 19, 2012 6:59 pm
I would like to know what to use to. Red dirt stains don't come out.
Should I leave it in the truck and drive through the car wash like I did the dog? You should see a freshly rainex'ed dog on a hardwood floor when you run the can opener. LOL.
PostPosted: Tue Jun 19, 2012 8:34 pm
You might try a bottle of hydrogen peroxide and a small brush. I haven't tried it, but would give it a shot for an organic stain. 8)
PostPosted: Wed Jun 20, 2012 5:23 am
x2 - my wife works in the veterinary field and comes home with blood stains all the time. A small amount of Hydrogen Peroxide does the trick every time.
2019 Hobie Outback | 2018 Hobie Compass | 2017 Hobie Revolution 13
Froggin' For Bass and Other Kayak Adventures
PowerTeam Lures - deadly on bass!!! use promo code "HANOVER" at checkout for a 15% discount
PostPosted: Thu Jun 21, 2012 7:56 pm
Try a Mr. Clean Magic Eraser. That's removed lots of stains from my PA.
PostPosted: Fri Jun 22, 2012 6:13 am
Wet a small area with the stain and squirt the paste over it and rub it in.
Let it set for a while and then use a small hand scrub brush with circular motions and let it set again. Rinse and scrub while rinsing.
Great toothpaste and removes a lot of organic stuff from many surfaces. Be careful using it on cloth unless the cloth is white.
2009 Oasis
2012 Freedom Hawk Pathfinder
PostPosted: Wed Jul 11, 2012 1:28 pm
Mr Clean Magic Eraser works for everything. It is amazing.
PostPosted: Wed Jul 11, 2012 11:07 pm
I use a pressure washer on my kayaks and that does the job great. I use the same oscillating nozzle for vinyl siding to get the stains out. It's more powerful than a car wash, so you have to be careful around decals and the soft rubber rudder handle. I mucked up the handle on my sport, and it completely removed the decals off my wave, but it's quick and you don't need chemicals.
PostPosted: Sun Apr 07, 2013 6:48 pm
A boat detailer that I know swears by a product called "Bar keepers Friend." He says it will cleans rust stains, that black slime stain, fish blood and won't harm the surface. I didn't ask him about plastic boats though.
