It is currently Tue Aug 11, 2026 11:38 pm
 Post subject: trailering the PA 12
PostPosted: Wed Jun 20, 2012 9:14 pm
I bought a PA 12 day before yesterday and will pick it up tomorrow. I've been working on my utility trailer today building cross beams to carry the kayak. After reading a few topics on here, Im wondering if Im going to be doing the kayak harm. Should I put it on the trailer upside down or rightside up? What Ive done is bolted 2 2x4's down across the trailer with the wider side of the 2x4 making contact with the kayak. I did reinforce this with another 2x4 screwed to the cross sections in a vertical position. I then covered the cross boards with carpet. Another thing, Am I really supposed to store this thing on the hand rails?
just add water
 Post subject: Re: trailering the PA 12
PostPosted: Thu Jun 21, 2012 6:05 am
From my research for my PA14, I've found that...unless you have the Hobie Cradles, the best method is having two 2 or 4 inch PVC pipes bolted to a trailer. The pipes should be arranged to run along the scupper holes along the bottom of the PA. I would assume the same would be for the PA12.
Check out Tom Kirkman's video on youtube. I believe his handle on youtube is tomkirkman1.
2011 HPA
2006 Wildy Ride 135
2019 Hobie Compass
2020 Hobie Outback
PostPosted: Thu Jun 21, 2012 11:41 pm
Thanks mucho Red. Looked at the video. Not only will I upgrade my trailer but also store at home like this. Thanks so much for the info...
just add water
