It is currently Sun Aug 09, 2026 12:12 am
PostPosted: Sun Jul 15, 2012 4:33 pm
I bought a new main sail for my H17. Having trouble getting it to latch. One thing I've noticed: the halyard is too fine a rope to stay in the luff track - as I pull it, the portion of the halyard attached to the head of the sail will jump out of the track. Somehow this never caused problems with my old sail but think this may be an issue. I assume the halyard (again the portion moving upward) should stay in that track? No? Anyone know what diameter rope should be used if this is the case?
Thanks for the help!
Adam
e-mail: ab at medjet.net
H17S, Hobie Bravo, A cat
Fleet 444
PostPosted: Sun Jul 15, 2012 5:12 pm
Yes, the halyard should stay in the track, forward of the sail's bolt rope.
Newer sails (at least the OEM ones) have a Teflon-impregnated bolt rope cover that is more slippery - and can let the halyard escape out the track. Usually, this isn't a problem when raising the sail (assuming the halyard is fed through the center sheave at the base of the mast), but more when sailing, when the halyard escapes from inside the Comptip track when it flexes. Makes it really hard to get the sail down.
I used to have an Spectra halyard that in addition to being small diameter, was very slippery. It came out all the time.
I have since switched to a 4 mm Dacron/Spectra line that hasn't come out of the track yet.
PostPosted: Sun Jul 15, 2012 5:54 pm
No. The portion of the halyard that shackles to the head of the sail, the portion moving upward, does not go in the luff track. Only the portion of the halyard which is moving downward goes inside the luff track.
PostPosted: Sun Jul 15, 2012 6:04 pm
Oops. I think my question is should the downward going portion (not upward) stay in the track. Bottom line for me: both sections are out. Sounds like it's not supposed to do that. Thanks!
Adam
Fleet 444
PostPosted: Sun Jul 15, 2012 6:18 pm
Can I ask you guys another question: If I replace the halyard, I know I'm supposed to tie some low profile knot to the ring shackle. Is there a particular type of knot? Sounds like bowline maybe not a good choice...? thanks again.
Adam
Fleet 444
PostPosted: Sun Jul 15, 2012 6:48 pm
There are several different knots you can tie.
Some people use a buntline hitch (http://www.animatedknots.com/buntline/i ... dknots.com)
But that still leaves the bulk of the knot outside the ring.
I use a combination of an overhand knot at the end of the halyard and a clove hitch. The overhand knot keeps the bitter end of the line from slipping through the clove hitch. This combination has almost zero bulk between the ring and the halyard sheave so you can get the maximum hoist.
