It is currently Mon Jun 15, 2026 3:40 pm
PostPosted: Sat Jul 22, 2006 1:14 pm
I´m thinking on upgrading the 81 stock main sheet blocks on my h18 would these be the correct? is 57mm the wright size?
Harken 57mm Triple Carbo Block w/Becket HAR-2605
Harken 57mm Triple Carbo Block w/Cam Cleat HAR-2617
Both are listed on ebay
The actual setup has 3 separate blocks on the boom, is it better to have single triple block on the boom or 3 single ones???
What are the best blocks for this setup?? Thanks
PostPosted: Mon Jul 24, 2006 8:09 am
Here is the long answer, now bare in mind, I have a h16 not an h18 not sure if that matters much.
Matt will probably strongly dissagree with the carbo, but as I mention, they are not that hard to adjust.
http://www.catsailor.com/forums/showfla ... &fpart=all
Sam
PostPosted: Mon Jul 24, 2006 8:43 am
I run a 8:1 harken carbo hanging from the middle bail. Same as the Fox or Tiger. It has bent the bail a little from the angle of purchase. Can get the blocks to almost touch, much easier than the triple/single original. Saw some used on thebeachcats.com couple of weeks ago. Those are not cheap but worth it as compared to the seaway originals.
PostPosted: Mon Jul 24, 2006 8:55 am
57 mm will work fine, 2 1/2" or 3" also.
All newer boats have triple upper blocks.
Which is best is subject to personal preference (I like the rachetmatic lower, had the carbo rachetmatic on our 18 and didn't like as well).
Add a single 40mm (1 1/2") standup block above the cam cleat on your lower and you'll have 7:1 :D the more the merrier.
Fleet 297
PostPosted: Mon Jul 24, 2006 10:09 am
Actually, if you get beckets on both upper and lower you can get 6,7,8(with pully):1
PostPosted: Mon Jul 24, 2006 11:57 am
I'm with Matt on the lower Carbo Air blocks - too much trouble to adjust. I had to remove mine from the traveller car to adjust the cam angle, and prayed the little nut holding it together didn't drop in the sand. But if you're a set-it-and-forget-it sailor then go ahead and get them, since they'll be an improvement over the old ones. You might also want to replace the main sheet with the new blocks.
PostPosted: Mon Jul 24, 2006 1:52 pm
Yes you should disconnect them from the car, however that was not that big of a deal, I use a quick release there. Also took the nut all the way off and set it on the tramp. This allows you to work better with the bolt side out a bit, set the bolt side, than place the nut side cap back inplace install the nut and tighten.
as for as the sheet goes, yes do replace it. I don't know about other brands and makes because this is my first "real" new sheet, but I am very happy with the sheet I got.
Sam
