It is currently Tue Aug 04, 2026 10:08 am
 Post subject: Worn out drive unit
PostPosted: Sun Jul 23, 2006 11:48 am
I am still working on my worn drive unit. Are there any blow-up diagrams of the old style drive? I have the catalog and it only shows new drive style parts. I know it has the list for older parts, but I need a blow up. Thanks, pearly
PostPosted: Sun Jul 23, 2006 9:38 pm
Click on this and see if it is large enough. If not, I can send it larger.8)
 Post subject: exploded diagram
PostPosted: Mon Jul 24, 2006 5:26 am
Thanks Roadrunner,
I need part 24, but can't read it. Can you please send it a little bigger? I tried magnifying the pic, but couldn't.
Pearly
PostPosted: Mon Jul 24, 2006 8:56 am
I'll re-send tonight. In the meantime, part #24 is 8030100 (10 x 24 x 7/8"THMS. I believe this is a clevis pin. If it's the plastic u-shaped black piece (the pin goes through it) you're after, that would be item #1, part # 81040 (outhaul block).
 Post subject: Expanded view
PostPosted: Mon Jul 24, 2006 10:11 am
thank you very much. I need the outhaul block. it s funny name. I wonder why it isn't called the clevis. Pearly28
PostPosted: Mon Jul 24, 2006 4:21 pm
Lets hope this larger thumbnail works: (Click on this image, then again on the next image that appears and it will grow again!)
Hobie, being a sailboat manufacturer for so many years, was naturally well versed in all the nautical terms. So when the Mirage drive first appeared, they had to come up with names for all the parts. Since the fins reminded them of sails, they so named them and all the parts took their names from sail parts. For instance, the metal rod for the fin is called the mast. The rearmost attachment point of the fin is called the clew. The outhaul block, which the clew normally attaches to is symbolic of what you would find in the corresponding position on a sailboat.
So, Avast, matey, once you get your sailing terminology down, twill all make sense! 8)
 Post subject: Sails or fins?
PostPosted: Tue Jul 25, 2006 6:03 pm
Sails or Fins?
We first called the MirageDrive a Hydro Sail.
