It is currently Tue Aug 11, 2026 11:32 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Hull protection?
PostPosted: Wed Jun 27, 2012 9:43 pm
I have not done anything about protecting the hull of my Pro 12 yet but I did use Recrepair skid plates on my Outback. Not to difficult to install and have stayed in place during beach launches and landings for the last 6 months.
http://recrepair.com/skid_plates.html
PostPosted: Thu Jun 28, 2012 9:32 am
Go to your local hobby place and get the clear 3M paint gaurd used on fender wells of cars and use it on the keel. A heck of alot cheaper. :idea:
Steve Valerga Jr.
DV U.S.Army Airborne
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Thu Jun 28, 2012 6:23 pm
I use a hambys keel shield on my bass boat and beach the boat on granite and the ramp all the time. This stuff is about indestructible. I'm sure it will work on a yak.
http://www.hambys.com/
PostPosted: Thu Jun 28, 2012 9:06 pm
At $200 for a 5" wide X 6' long strip of Hamby's lite, that is a wee bit rich for a kayak. :shock:
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Jun 28, 2012 9:36 pm
Your right. I forgot what I paid for that on my bass boat. I'm not rich anymore. Maybe that do it your self bed liner stuff. You could do the entire hull and sides for like 99 bucks. Costco sells the stuff. But it's permanent, no taking that stuff off.
PostPosted: Fri Jun 29, 2012 8:57 am
and it adds weight to your yak! :roll:
Steve Valerga Jr.
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Wed Jul 04, 2012 5:25 am
If your trying to protect the keel of your kayak, you need to check out Marine-Tex. When this stuff dries, it is like steel plate. I have used it on various kayaks for years. Not even the roughest concrete boat ramp can cause damage.
PostPosted: Wed Jul 25, 2012 4:35 pm
I just got a sample of the Keel Eazy strip for application to the keel of your kayaks. Played with the sample and it was easy to apply and shape with a heat gun. Have just order enough to protect areas of my PA. When I get it I will post pictures.
Plus, the cost was very reasonable
If you want to check out go to Keeleasy.com
PostPosted: Wed Jul 25, 2012 7:59 pm
Bedliner? How about spray on bedliner? It wont come off but is super tough. I don't know how much weight it adds.
http://www.linex.com/
PostPosted: Thu Jul 26, 2012 12:55 pm
Hey...Heres an idea :idea: ,How about just running a 1" O.D., 3/4" I.D. black vinyl tube the length of the PA on each side, with a piece of rope running through it, that is attached to the front and rear handles. And if you are worried about the tube slipping up and down, you could add a couple clamps evenly spaced along the tube holding it in place along the hull. Also, if you're worried that it might hold water, then just drill some holes in the tube BEFORE installing the rope through it :lol:...I think the biggest advantages though are that its fairly low cost and installs/removes easily and its light weight and strong...Heres a link where you can find it:
http://www.homedepot.com/Plumbing-Pipes ... reId=10051
PostPosted: Fri Jul 27, 2012 3:18 am
read post kinda late but i am considering stuff like keel gaurd fo my pa 14 for protection may be could use on side for protection
