It is currently Thu Mar 26, 2026 7:09 pm
 Post subject: My rigged Revolution 13
PostPosted: Fri Aug 10, 2012 7:02 am
The plan was to get out this morning for some bass fishing, but weather changed my plans. Instead I made a couple of adjustments to my boat and thought I'd share. Any comments/ suggestions/ questions are welcome!
Hobie Revolution 13
-Sidekick outriggers (stored in front hatch when not in use)
-Scotty gear mounts
-Humminbird 170 Fishfinder - Just relocated the transducer to its current location. It was a "thru hull" installation but couldnt fix the bubbles which lead to inconsistent readings
-The rod holder in the front is simply 2 pieces of pvc. One smaller that fits in the hole, then one slightly larger on top so the rod holder can swivel. Scotty rod holder is glued in the pvc.
-Battery is in the front hatch
-"Stick It" anchor pin
Hobie Revo 13
PostPosted: Fri Aug 10, 2012 7:07 am
Your links require that people have an account to see them In order to post pictures you need an account with a photo sharing website like Photobucket to host the pictures and then you can put in the image code in your post to show the images.
MrGreen
PostPosted: Fri Aug 10, 2012 7:10 am
Ok let me see if I can figure this out...
Pics added above
Hobie Revo 13
PostPosted: Fri Aug 10, 2012 12:30 pm
I've always wanted to know, for kayak anglers who use the milk crate idea, where do you put your catch? or are you more into catch and release?
I would do this, but I put a large catch bag in the trunk area.
PostPosted: Fri Aug 10, 2012 1:24 pm
I personally do not keep any fish I catch, but I believe many would keep fish in the large front hatch on ice.
I target largemouth bass (in freshwater) and redfish, trout, and flounder (in saltwater). I try to get a quick picture and return the fish to the water as quickly as possible
Hobie Revo 13
PostPosted: Fri Aug 10, 2012 1:36 pm
gotcha!
I target Mackerel, Kingfish, Tuna and Amberjacks when I go offshore (75% of the time) therefore long catch bag required. Trout and Pompano are the goal when I go inshore (remaining 25% of kayak time), which is when I use a small insulated bag in the front hatch as you mentioned.
I also like the placement of the fish finder. I think I will use the quivalent spot on my Revo11 when I get the fish finder.
PostPosted: Fri Aug 10, 2012 5:15 pm
Do you find that the transducer bracket creates any drag when under way?
PostPosted: Fri Aug 10, 2012 5:20 pm
take a closeup picture of your transducer mount. Is that yakattack dogbones you used.
PostPosted: Fri Aug 10, 2012 7:22 pm
I have only been out once with the transducer in its current location. There was some turbulence when peddling at a good pace. It did not seem to slow me down or have any effect on tracking or depth readings. I am working on making the mount a little more aerodynamic (bolts instead of the large scotty knob). Worst case I can adjust the arm to the up position if I am going a long distance and dont need a depth reading. This is definately a negative of this mounting option, but the improved readings over my through hull installation seem to be worth it. There was a lot more detail on my screen when paddling over stumps, bait, fish, and other structure. Ill post some updated pics after a couple experiments.
All the mounting hardware is Scotty. There is a quick release which extends the arm over the edge of the boat (parallel to the water) and an extension arm which drops the transducer vertically into the water. I modified one of the Scotty "male" plugs to mount the transducer to.
Hobie Revo 13
PostPosted: Fri Aug 10, 2012 8:00 pm
Cool thanks
PostPosted: Sat Aug 11, 2012 12:35 pm
Did you you consider a mad frog liberator for your transducer mount.
PostPosted: Mon Aug 13, 2012 5:17 am
The reason for using the Scotty parts for my mount is because that is what already had. Originally I had the transducer in the hull, a Scotty extension arm on the fishfinder and an extension arm on a rod holder on the right hand side. It seemed too cluttered and I rarely found myself using the rod holder up front. Using the parts I already had I reconfigured to this setup. I took it out yesterday to a lake and the detail was much improved over the thru hull transducer.
Ill see if I can get some close ups of the transducer mount
Hobie Revo 13
