It is currently Fri Jun 26, 2026 4:19 am
 Post subject: security
PostPosted: Sat Aug 11, 2012 5:15 pm
Currently I am running a cable thru the scupper holes onto a fixed point on my transport vehicle. I was wondering if anyone has a better solution?
 Post subject: Re: security
PostPosted: Sat Aug 11, 2012 8:27 pm
I do the same thing. Will be curious to see what kind of ideas this leads to. :?:
Even if you fish all day without a catch, you're still better off than the worm!
PostPosted: Mon Aug 13, 2012 7:33 am
Also the mirage drive hole is a good place too, depending on where you are attaching to the car/truck. As long as the kayak does not slip or move the scupper hole should not be a problem or weak spot. Good Luck
