It is currently Wed Aug 05, 2026 4:03 am
PostPosted: Mon Aug 20, 2012 6:21 am
On Saturday I noticed that my left peddle wobbles when I am pedaling. I have a 2007 Outback and I after close inspection I think I need to replace the left injected molded drum. When I took the mirage drive out I did a close inspection and notice a little play in the left peddle but the right peddle has no play.
Has anyone out there had a similar experience and how was it resolved?
PostPosted: Mon Aug 20, 2012 6:54 am
Tighten the chain equally on both sides.. The one side that wobbles might need more turns then the other, but make sure that the chains aline and keep the peddles equal in the center line. Hopes this helps... Good luck.
PostPosted: Mon Aug 20, 2012 7:39 am
Agree - Was having the same problems with my old Outback. Adjusted the chains and the problem went away.
