It is currently Wed Aug 05, 2026 4:09 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Fri Sep 21, 2012 6:43 am
Ok, just to clarify to my inner dope...
Some of you are putting a safety line on your mirage drive EVEN WHILE you have the drive locked in place? Not sure that's needed.
Ever since I ventured into this discussion, every damn time I pull my drive coming up to a beach or dock somewhere, I think I'm going to accidentally lose it in the water. :o
Getting two carabiners today.
PostPosted: Fri Sep 21, 2012 7:43 am
If the Mirage drive leash is already on (before even hitting the water) then it can't drop overboard to the bottom when putting it in or taking it out. :)
PostPosted: Fri Sep 21, 2012 7:55 am
It's not needed while the drive is locked into the drive well, but once you attach the lease (it clips on or off in a second) there is no reason to disconnect it when you drop it in the well. I attach mine in the parking lot before I hit the water. Once in the water a couple feet out, drop it in the well. When returning, I remove the drive and lie it in the cockpit somewhere, leash still attached. I only un-attach it once back on dry land. The leash isn't in the way of anything.
cron
