It is currently Wed Feb 11, 2026 5:01 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: Wed Sep 19, 2012 4:52 pm
Finally cleaned off 31 years of old contact cement from the rails on our new (to me) 1981 H16, used in abundance to glue down the carpet.
Any recommendations on replacing this -
with carpet:
http://sailsportmarine.com/index.php?main_page=product_info&products_id=673
or neoprene:
http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Store_Code=MS&Product_Code=30-210&Category_Code=
or... ?
Suggestions welcome!
1981 Hobie 16 Tequila Sunrise
PostPosted: Wed Sep 19, 2012 5:22 pm
You can spend the $$ for a kit but this is what I used. It's been on my boat for over a year and holding up very well.
http://www.lowes.com/pd_97913-1761-ST10 ... oor+carpet
..and I have enough left over to do it again.
PostPosted: Wed Sep 19, 2012 5:38 pm
Garret has a good solution - the end result would be the same as the carpet kit and you save $$. We opted for the neoprene kit from Murrays. Does not hold water so your backside stays drier. :P
Jonathan
'85 H16 __/) 87468 Tidal Wave
PostPosted: Wed Sep 19, 2012 6:43 pm
Surprisingly the carpet holds very little water but Neoprene is good stuff too. If your backside isn't wet you are not on a H16. :D
PostPosted: Wed Sep 19, 2012 7:23 pm
True that 8)
Jonathan
PostPosted: Thu Sep 20, 2012 4:40 am
This is what I did. It turned out that the width of the carpet (8' I believe) was about 6" short to cover the entire rail. So we went back into lowes and borrowed a few 6"x6" samples to finish it off :roll: Can't tell and it has been holding for a year :lol: .
Zach
PostPosted: Thu Sep 20, 2012 6:32 am
NEOPRENE every day have used carpet did not like
Just put on a kit from Murrays Marine very nice
Former Hobie Admiral Gary
PostPosted: Thu Sep 20, 2012 6:40 am
Two choices to avoid that. Use 12ft
Width or they also sell 30" runners on a big roll. I went with the runner. It also gives you two nice factory edges to work with. You can put the edge you cut under the rail.
PostPosted: Thu Sep 20, 2012 10:38 am
One word:
Hydroturf
http://hydroturf.com/products.php?cat=S ... Hydro-Turf
Lighter than neoprene, with none of the bad habits (water retention) of carpet.
Bit pricey, though, especially when you add in the adhesive.
PostPosted: Thu Sep 20, 2012 10:59 am
But your backside dries faster than carpet. And getting your shirt or shorts wet long after you finished sailing and dried out is just enough of a pain to make me go with neoprene.
PostPosted: Sat Sep 22, 2012 10:40 am
MBounds wrote:
One word:
Hydroturf
+1 on the Hydroturf. I've installed it on both of my H18s and really like it. Very good grip and quite durable, after 2 summers of sailing it really isn't showing any signs of wear.
I bought a full roll of the long diamond cut (4.5mm thick) that was on close-out for $40 and used rubber cement to install it. Certainly took longer than the 3M adhesive backing would have, but being careful it ended up just as clean and it hasn't started to pull up at all. Plus, I still have enough left for at least another boat, maybe 2. Even at full price, a roll is a pretty good value, and you can always sell your left overs.
-Pete
PostPosted: Mon Sep 24, 2012 3:52 pm
I had the carpet on my boat and when it deteriorated I bought the neoprene kit. I really like it a lot. Haven't had the desire to explore the DIY options.
My only gripe (and this probably applies to any rail rug) is that the trap shock cords hang up on it. But so far it hasn't torn; it just gets indentations.
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
PostPosted: Tue Sep 25, 2012 2:49 pm
I put the neoprene kit from Murrays on about 4 years ago, and still very happy though as one said it got a few little indents in it, I think from the straps I used to squeeze the rails when I put on a new tramp.
I sailed a boat once that had some stinky mildewed carpet on it. Did not like that.
The Murrays kit also came with pieces you can put on the back decks if you want to trap out way back on a reach, which I don't. I should probably put them on the boom for my annual accidental jibe.
scott
PostPosted: Sun Sep 30, 2012 8:53 pm
Jimrude, what did you find to be the most effective method of removing the old contact cement? I'm about to replace the old carpet on my 14 with neoprene.
Mark Van Doren
H14T Fantasia #47787
San Juan 28
PostPosted: Mon Oct 01, 2012 7:32 am
MVD wrote:
Jimrude, what did you find to be the most effective method of removing the old contact cement? I'm about to replace the old carpet on my 14 with neoprene. Thanks,
MVD - we recently replaced the carpet with neoprene. The carpet was rotten so the rail looked more like a mangy dog than something that would pull off in one piece. We used acetone and gently scraped it while wet with a putty knife and steel wool. Then cleaned it well one more time with acetone before applying the new cement. (make sure you are working in a well ventilated area or better yet outdoors).
Jonathan
