It is currently Mon Aug 03, 2026 2:40 am
 Post subject: Downhaul bends mast??
PostPosted: Wed Aug 02, 2006 5:00 pm
Ok I'm new to this. I've been messing with the downhaul on my 79 to see how it effects sail shape, but mistly I notice that if I set up the downhaul as a block-tackle to get some pull, it just bends the mast tip over!
I did not take the time to figure out what I had for advantage, but it was likely 3:1 or so.
How tight to pull the downhaul? Does it really help with sail shape? What does everyone else do here???
-jeff
PostPosted: Wed Aug 02, 2006 9:59 pm
I am concerned that your mast might not be perfectly straight... compressing the mast with the down haul might exaggerating on that imperfection.
Down haul tension is important... there is a limit (marker / tape) on your mast.
Patrick
PostPosted: Thu Aug 03, 2006 4:49 am
Yes, my mast is not perfectly straight. Me pulling on the downhaul does exacerbate the problem.
At this point, I've read many posts on bent masts, and I'm not sure I want to try and straighten it. It seems that kinking the mast is a possible outcome that I don't want. The bend is slight, until you crank on the downhaul.
I don't have any indicators on my mast, how far down to pull? How tight?
Any easy mast straightening tricks? I can't see myself yanking on the base with the tip stuck in forked tree.
-jeff
 Post subject: Mast bends?
PostPosted: Thu Aug 03, 2006 12:26 pm
Mast bends when you downhaul. Yes...this is normal. The downhaul forces the mast to compress. Now, if the upper section is bending independently, that may be a loose CompTip? Check to see that the CompTip is properly glued in. The Tips do bend a bit more than the lower section.
