It is currently Wed Aug 05, 2026 2:11 am
PostPosted: Sat Oct 27, 2012 11:43 am
I was down my local Hobie centre today and I was after a sailing rudder to upgrade the standard item on my Outback. He didn't have one in stock, though I was given an older style tandem rudder (I believe) to try FOC. It fits a treat, though is a couple of inches longer than the sailing rudder. It raises and lowers just fine without undue effort. So what do you reckon?, too large??. I could trim is down and profile it if required. I've only just fitted it and not tried it on the water yet, though I do have a sail kit and intend to sail it from time to time.
Standard rudder
Sailing rudder
Tandem rudder
Follow my blog @ Saltwater Kayak Fisherman
Watch my videos on You Tube
Team Hobie GB
Lowrance Pro Staff
YakAttack Pro Staff
Hook1 Crew
PostPosted: Mon Oct 29, 2012 11:25 am
I would try it out on the water before trimming any part of it off. The larger rudder might just be the thing to have. Good Luck and let up know how it worked out.
PostPosted: Thu Nov 01, 2012 9:18 am
The large size of the rudder will add drag. That would be the only real issue. I think it is over-kill on an Outback unless... maybe sailing it.
PostPosted: Thu Nov 01, 2012 11:51 am
You may well be right. It didn't cost me, if it's not suitable I'll put a sailing rudder on. It'll be tested in a week or two, first I've got a trip to Texas!
Team Hobie GB
Lowrance Pro Staff
YakAttack Pro Staff
Hook1 Crew
PostPosted: Sat Nov 10, 2012 5:49 pm
KEEP the sailing rudder , The outback is far more responsive , turns on a dime AND tyrcks way better with the extended rudder .
KEEP IT
You will be VERY HAPPY you didnt trim it .
I up graded my outback ,with a sailing rudder and couldnt be happier
PostPosted: Sat Nov 10, 2012 9:19 pm
I'd keep a spare rudder pin in the boat just in case the larger rudder adds more force to the pin, but if it works, why not keep it? It should give you what you're looking for, and the price was right!
