It is currently Tue Aug 04, 2026 7:51 pm
 Post subject: Pro Angler Seat
PostPosted: Fri Dec 14, 2012 7:43 am
If I purchase a 2012 or older Pro Angler can I put the new 2013 seats on them?
 Post subject: Re: Pro Angler Seat
PostPosted: Fri Dec 14, 2012 9:20 am
Have you priced the seat?
Cathedra Mea, Regulae Meae.
PostPosted: Fri Dec 14, 2012 9:46 am
No - there isn't a way to convert to the Vantage seat unless the boat has the required built in structure to support it. Sorry. If you want the new seat you need the current design kayak, same with putting an old style seat onto a new hull, that also isn't something that is possible.
Jacques Bernier
http://www.hobie.com/
PostPosted: Fri Dec 14, 2012 10:35 am
I don't want to assume anything, but if you haven't, you should try the older seat. You might prefer it.
PostPosted: Fri Dec 14, 2012 12:33 pm
I looked at the older seats and I was not for sure if they were low enough for a comfortable paddling.
PostPosted: Fri Dec 14, 2012 2:22 pm
If the paddle is long enough I suspect it would be, although I've never bothered to paddle my PA.
PostPosted: Sat Dec 15, 2012 10:42 pm
There is so many options for the seat area on the Pa's. I have seen plush boat style seats installed and everything in between. I would google Pro Angler seat mods or changing seat on Pro Angler.
PostPosted: Mon Dec 17, 2012 3:35 pm
To the root of your question...
Paddling is not a strong suit for the Pro Angler and why we consider it a Boat rather than a Kayak in our line.
If I were to choose a boat for paddle and pedal, I'd look at the Revolution or Adventure models.
PostPosted: Tue Dec 18, 2012 10:58 am
+1
Revo paddles well some correction needed, the adventure paddles very well
Currently own: 2012 AI, 2 - 2012 Revo 13's, 2012 Revo 11,
Sold: 2-2011 Oasis, 2010 Outback, 08 Outback, 08 Adventure, 06 Kona
PostPosted: Wed Dec 26, 2012 8:16 pm
Uploaded with ImageShack.us
Here's a pic of a seat mod that i mentioned in my above post. Very very simple to do. This is the seat i had in my Outback. I found this pic in Hobie's archives.
PostPosted: Thu Jan 03, 2013 7:51 am
i sure would like to see the bottom side of the yak with the trolling motor fixed in that location. Wow, someone has learned a really good way to seal holes in the bottom of the yak.
PostPosted: Thu Jan 03, 2013 8:48 am
I imagine that's just the powerhead mounting location.
PostPosted: Thu Jan 03, 2013 12:13 pm
OH, does that mean that the shaft does not go all the way through the yak in that location?
