It is currently Thu Aug 20, 2026 12:09 pm
Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Apr 04, 2012 3:56 pm
Again we're talking to different things, the PA is a boat, it's not a kayak, the hull configuration is much different. Tom now we're putting Gas motors :shock: on these things, get it back to electric motors.
Tightlines
Steve
PostPosted: Wed Apr 04, 2012 4:11 pm
We put a gas motor on it to find out if there was any sort of hull limit in terms of speed. Just as we thought, you can continue pushing the PA faster and faster until and unless you can no longer steer it in a straight line.
Once we figured out that it wasn't the hull that was the limiting factor, we pushed forward with making a better prop. And we did.
Nobody told our PAs that they weren't kayaks. Please don't let them in on the fact that they're boats - if they find out they're boats we might no longer be able to get them to go more than 5 MPH.
PostPosted: Thu Apr 05, 2012 4:30 pm
One issue you're not looking at with the evolve is the battery replacement once it goes in a few years. Know your options front to back once you get involved in a motor system. There are pros and cons to anything out there, I must say you do get what you pay for. Whatever you may buy, have fun with it guys.
PostPosted: Wed Nov 14, 2012 8:30 pm
With the bigger center hatch on the new 12's and 14 battery storage become less of a problem. 2 22-NF agm's fit perfectly in the center hatch after removing the plano tray. The Powertec brand fit perfectly between the scupper tubes. This also allows the weight to be centered in the hull away from the bow.
http://www.flickr.com/photos/89112512@N ... /lightbox/
PostPosted: Thu Nov 15, 2012 11:03 am
I thought I'd share my knockoff version of the Bassyaks trolling motor set-up, complete with my do-it-yourself instructions.
I already had the trolling motor (minn-kota 30lbs), so the set up only cost me $70.58. $40 of the total was on the stainless steel mounting bracket, which I had fabricated locally.
https://plus.google.com/photos/114227061240820045982/albums/5803684343522828625?authkey=CJzr7vGKwrI9
I hope you find this a time saver and useful.
Kip
PostPosted: Thu Nov 15, 2012 4:54 pm
They will last for many, many years...
Lithium battery life expectancy: The life of a lithium battery is barely affected by charging cycles. It has no memory effect. Therefore, the battery can be fully recharged after every trip, regardless of the charge status shown on the display. Generally, a loss of capacity of 4% per year can be expected. Ageing is accelerated if the battery is exposed to high temperatures for long periods while fully charged.
Our recommendation: The battery can be used in very hot conditions but should be stored in a cool place away from the sun when not in use. 8 years after date of production, your battery needs to be inspected by a service center.
http://torqeedo.com/us/electric-outboards/ultralight-403-with-integrated-battery-for-kayaks-and-canoes/usage-information
PostPosted: Thu Nov 15, 2012 8:25 pm
KIP, That's nice but your not even close. lets see that in 2 months of use.
3M tape??, the stainless steel is a nice touch!
PostPosted: Thu Nov 15, 2012 10:40 pm
Matt .......... also the Lithium battery can be fully discharged where as the lead batteries usually only get about a 50% discharge before they fall below the 12 volt range so they last longer on the water ......
PostPosted: Fri Nov 16, 2012 5:36 am
Kip
Nice, thanks Kip.
PostPosted: Sat Nov 17, 2012 2:54 am
Kip
Thank you very much do-it-yuourself instructions. Now to make one too.
What thickness was the SS bracket. And do you have a way raise and lower the motor form the seated position?
PostPosted: Mon Dec 10, 2012 2:41 pm
My mounting bracket is 1/8 thick. As far as raising and lowering...I use it primarily on the ocean, so I don't have a need really to raise and lower it. With that said, my next project is to find a way to do just that. But, it's low on my priority list.
I'll keep you posted.
Kip
PostPosted: Mon Dec 10, 2012 2:45 pm
Well, it's kind of close and does exactly what I need it to do...propel my PA. And, your right...the tape I used is not even necessary. The switch stays in place perfectly without it. By the way, I have used it over 20 times now and it works perfectly every time. I love it!
PostPosted: Tue Dec 18, 2012 9:38 am
Lets see it
PostPosted: Mon Jan 07, 2013 1:47 pm
SteveK....Not sure what you mean, "Let's see it". Just click in the link in my original post.
PostPosted: Mon Jan 07, 2013 5:46 pm
I can't see anything either...just a white screen with the google rectangle???
PA 14; 2012
Cape Fear River - NC
