It is currently Thu Aug 20, 2026 6:30 pm
PostPosted: Mon Dec 31, 2012 3:23 am
Hi Guys,
Recently picked up a 2001 A.I. and finally assembled it (in the garden!) today. When I had the sail out I noticed that the furling line seemed a bit short (it was almost out or reach).
This is how it's currently rigged:
Does that look okay?
And this is how much mainsheet and furling line I have when the sail is fully furled. Again, does this look about right?
Being an A.I. newbie, I'd appreciated any comments or suggestions on re-rigging or adjusting the lines.
Cheers,
Mike.
PostPosted: Mon Dec 31, 2012 9:03 am
The downhaul line and furling line aren't supposed to be the same line. The downhaul line is the same type rope, but should be supplied as a short section. This may be why you don't seem to have enough furling line when the sail is fully opened.
PostPosted: Mon Dec 31, 2012 1:34 pm
Mike,
What Tom said! :)
Did you get the manual with the boat? If not you can download it from the support links in the FAQ's here:
viewforum.php?f=114
All the FAQ's should be required reading for any new AI owner. Especially note how the daggerboard bungee is threaded.
PostPosted: Mon Dec 31, 2012 2:58 pm
Something else you might be interested in if you want a 3 to 1 system for both people - it can be done with the same sheet, assuming you have communication between the "crew" while underway.
http://youtu.be/3EU0QV7ssNQ
PostPosted: Tue Jan 01, 2013 2:08 am
Thanks for the replies guys...
I have a copy of the A.I. manual (although the copy I downloaded still refers to the 'older' style A.I. - published September 2006!).
Any chance of a few photos of your setups?
Also, can anyone suggest the type of knot I should use. I'm a bit hopeless in this area - I know a few fishing knots, but nothing that's of any use when rigging an A.I.!
Cheers,
Mike.
PostPosted: Tue Jan 01, 2013 6:06 am
I use a bowline on the attachments points on the sail and first pulley.
PostPosted: Fri Jan 04, 2013 6:12 am
Thanks again for the replies...
It's all sorted now.
