It is currently Fri Mar 27, 2026 1:14 am
 Post subject: As Promised...
PostPosted: Sat Feb 02, 2013 1:58 pm
http://www.youtube.com/watch?v=SNzLB8-g ... e=youtu.be
 Post subject: Re: As Promised...
PostPosted: Sat Feb 02, 2013 5:56 pm
Very nice Tom Great job on the video, narration and the motor mount itself.
PostPosted: Sat Feb 02, 2013 6:11 pm
Well done, much clearer than the in-shop first edition. I like the "kick-up" idea with the threaded rod, will make another one with that addition, but there will have to be some provision to prevent the motor from climbing out of the water due to thrust.
PostPosted: Sat Feb 02, 2013 6:36 pm
The motor won't climb out - if the kayak is free to move on the water, it'll move rather than the motor kicking up. Whatever takes the lesser amount of force is the thing that'll give. So just make the tension such that it won't release from motor power alone.
Also, if you do hit something. there is very little force on the rod holder tube. The main force will be on the side of the hull, where the horizontal motor mount tube sits. This is spread over a pretty good area of thick plastic so it's not likely to be a major concern anyway.
