It is currently Wed Aug 12, 2026 5:59 am
 Post subject: Question?
PostPosted: Tue Mar 05, 2013 9:56 pm
I am making a trip to Sand Hollow lake later this month and want to lock my PA 14 to the trailer. Is running a chain or cable through the mirage drive the best way to keep it from being stolen?
 Post subject: Re: Question?
PostPosted: Tue Mar 05, 2013 10:41 pm
Yes. It s a sensible way to lock it up
Unless you can keep it inside
Cc
PostPosted: Wed Mar 06, 2013 7:16 am
They could cut the chain, if you want remove the seat as well, replacing or purchasing the mirage drive and seat probably wouldn't be worth their time.
PostPosted: Wed Mar 06, 2013 8:47 am
If they want it, they will take it :!: However, if you can slow them down, that may be the deciding factor for them to move on to an easier target.
I travel to tournaments/trips all the time. I simple purchased a good locking cable that I run through the scupper/mirage holes and secure to the trailer.
Haven't purchased one yet, but understand they are making cable's with sirens/flashing lights. Do a search on-line.
PostPosted: Wed Mar 06, 2013 9:09 am
I lock the rear handle to the support crossbar on the rear of the truck. Then I lock through the seat and did lock through the cart inserted from the top too. Now that cart is going to be long gone so I will lock the new trailer stuff down.
Hobie PA14 with a mod or two
PostPosted: Wed Mar 06, 2013 9:27 am
I run a cable thru the mirage drive opening, around/thru the seat and lock to the trailer.
My grandpa always said, "locks are meant to keep the honest people out."
If they want it, they'll find a way to get. I'll just do my best to make as difficult for them.
And a tip...I use a high quality combination lock, so I don't have to worry about losing the key during a trip or tournament.
Cheers
Drew
Cathedra Mea, Regulae Meae.
