It is currently Mon Mar 23, 2026 2:45 am
 Post subject: Wildcat Rudders
PostPosted: Sun Oct 14, 2012 9:04 am
Is it only us having problems with the WC rudders
We have the 2010 modeand the rudders loos grip in the middle of the run without any external reason.
We are now tightning it with a velcro and or a rope
Any Ideas?
It is the only WC in Israel so we have no one to compare with ;(
 Post subject: Re: Wildcat Rudders
PostPosted: Mon Oct 15, 2012 10:58 am
Likely you need to adjust the arm forward a turn or two - the ball needs to have pressure on it - if the ball just drops into the recess - that is going to let go - have the arm adjusted out 1 or 2 turns so that the ball has pressure in the cup and it will hold much stronger
Jacques Bernier
http://www.hobie.com/
PostPosted: Tue Oct 16, 2012 9:09 am
THX, we did that it took a while and the connector between the rudder @ the arm got a little bend and the story start all over
We made new connectors from stainless steel then new arms also from SS instead of aluminum every time it hold for a while and the story starts again
For now we are using a velcro or a rope to tie the arm so the rudder will not come up
The newer models (2011 and 2012) have the same mechanism?
PostPosted: Sun Mar 24, 2013 8:07 pm
I have a 2012 model. Just getting to know it. Same issue today, with 20tk+ rides. PITA. Tried tightening the bungee cords, but same happened. Will try adjusting rudder rods as well.
