It is currently Wed Aug 12, 2026 4:02 am
 Post subject: Rudder issue n 2012 pa14
PostPosted: Tue Mar 26, 2013 8:46 pm
When pulled as tight as possible, the rudder hangs 2-3 inches below top. I can easily push the rudder up by hand from here. Is there an adjustment I can make so that pulling the rudder cord raises the rudder all the way?
PostPosted: Wed Mar 27, 2013 8:12 am
Not really sure what could cause this - there must be a burr, or the spring is out of alignment - in any case, this would fall under your warranty - so just visit your nearest dealer can get the rudder fixed or replaced.
Jacques Bernier
http://www.hobie.com/
PostPosted: Wed Mar 27, 2013 11:17 am
I just bought the PA last week from a gentleman that only use dit for a year. Is the warranty transferrable?
PostPosted: Wed Mar 27, 2013 11:23 am
yes
Jacques Bernier
PostPosted: Wed Mar 27, 2013 2:09 pm
Are you pulling hard / far enough? I just tested one here. Seems to take a pretty good tug. The handle should pull out about 7" of line to get it retracted.
PostPosted: Thu Mar 28, 2013 7:36 pm
Afraid if I pull harder ill break the cord.
How do you transfer the warranty?
PostPosted: Thu Mar 28, 2013 7:46 pm
You won't break the cord, it's REALLY strong stuff.
As far as the warranty, I can't recall if there is an official process. If you have the original bill of sale that will be fine. The serial number can be used to determine the date of manufacture, but in the case of a boat like mine, I bought a 2011 Oasis in 2012, so the warranty doesn't start until the date of purchase. If you have a similar situation, the bill of sale might be more important than just the serial number, etc.
PostPosted: Fri Mar 29, 2013 3:26 pm
Visit a dealer and have them take a look and if needed, file a claim.
PostPosted: Mon Apr 01, 2013 6:27 am
As Matt said , Just go to the Dealer. Hobie is excellent at honoring warranty's and fixing their Yaks even when they are out of warranty ...... within reason of course.
