It is currently Wed Apr 22, 2026 4:13 am
PostPosted: Sat Apr 13, 2013 7:54 pm
The area under the set screw on my mirage drive spine cracked. The set screw lands on a flat on the shaft for the fins. The dealer said the spine is only around $20 (US), but since my fin shaft had already slipped out of place twice due to the screw backing out, I opted for what I think may be a better solution:
I drilled holes through the shaft and spine, and I sawed off half of the threads for the set screw. Here is the final product:
That's a 4-40 UNC stainless screw with a self locking nut in a 7/64 inch thru hole. The fix has been working great. See my web site at the link below if you would like more details.
Greg
Red 2017 AI and red TI 2019
PostPosted: Sat Apr 13, 2013 8:20 pm
Exellent repair - I too have had problems in this area.
Hobie engineers please take note
PostPosted: Sun Apr 14, 2013 9:47 am
True...a metal set screw in plastic threads pushing on an immovable steel part causing permanent strain in a thinned area of plastic under cyclic loading... I suspect it will not age well. A screw in double shear is usually a preferred connection. Maybe they were worried about corrosion of small parts, parts count, or the need for another tool (a #1 small cross point screwdriver).
This fix may have been easier than replacing the spine. I just punched the fin shaft out, drilled, then hammered it back in. Did not mess with the cables or the idler pulley. The process I feared was drilling through the stainless steel shaft. All I had was a hand drill (no press). Turned out, with a little oil and a sharp bit, it only took a few minutes of drilling.
Another tid-bit: The drive started clicking when the set screw came loose. I doubt it was the sound of the loose set screw tapping the flat on the shaft - I usually blame clicking on the cable to gear teeth alignment - but the drive does seem to operate more smoothly now. If I were a Hobie engineer I would consider purposefully loosening the set screw a turn or two and see if it causes clicking. That clicking sound is so annoying.
Greg
PostPosted: Mon Apr 15, 2013 4:59 am
Nice fix. 8)
Should be in the 'Repairs/Problems' section.
PostPosted: Mon Apr 15, 2013 1:38 pm
The shaft also needs a screw driver slot at the ends to allow alignment adjustment.
PostPosted: Mon Apr 15, 2013 5:17 pm
That's a great, simple idea. Certainly would make aligning the shaft when
re-assembling a lot easier.
